Help! My headlights aren't sealing properly!
So I went through the process of doing the DIY on blacking out my headlights.
After much blood, sweat, and tears, I was in the process of putting them back together last night. I was able to seal the first headlight flush around all edges. I reused the existing silcone and added additional silicone to adhese the lens cover and headlight together. A combination of a heatgun and oven at 225 degrees helped seal the two together. However, the second headlight was NOT as easy. I was able to get 3 sides to seal however even with the assistance of the heat gun and oven, the top side did not fit flush to the lens cover and headlight. Currently there is a half to a third centimeter gap between the headlight lens cover and the headlight body. Any ideas to a solution to this to get it to fit flush? I filled in extra silicone in the gap, if I leave it as is, will I still have moisture to be worried about? Ideas to why it will not fit flush? Is the original silicone not getting soft enough? Do I have too much silicone in the gap? Is the housing tab supposed to fit within the gap where the lens also fit into the headlight? |
Wern't you suppose to take most of the old silicone off and put new silicone? I think the old silicone is your problem, take off all the silicone off or most of it and then reseale it....hope this helps...
chad |
| All times are GMT -7. The time now is 06:04 AM. |
