Help jdm evo 7 tail install
just put in my evo 7 tails and now the brake lights wont work ive checked the connections 3 times now can some one help me please
Did you check the brakelight fuse ? :) |
no but the oem ones worked fine b4 and now none of them work im guessing its that do you know which fuse this is and what volt and why would it blow
Also did you check the lights with the ignition switch on ?
yes
Here is a link from the FSM. It shows the fuse panel location
http://www.4g63t.net/2005_FSM/GR00000200-80A.pdf |
Scroll down to page 80A-15
might be a stupid question and i'm not trying to insult your intelligence, but you did make sure you put bulbs in all the places they should be right?
