HELP! Car won't start
I have an Evo IX 2006. I just finished installing my JUN B.L. catback exhaust and the car won't start. IT cranks, but won't start. I've tried jump starting the battery.. Disconnecting the negative battery terminal.. and I don't know what to do. Please Help :banghead:
OK all fixed ! :D thanks to chad and my friend kelvin for helping me solve it. It turned out to be a blown fuse.. I believe it was like "Engine something" fuse.. I don't know which one |
anybody? C'mon.. I called Chad from JUN.BL. and he talked to EvoDave.. they said it might have been a blown fuse or some sorts.. Any other suggestions?
check the fuses there should be no correlation between installing exhaust and car not starting
The dreaded exhaust malfunction,i hate it when that happens. :lol:
i mentioned grounds, power for starter, possible fuse ....just push start it and verify it runs.....push it and have someone in it get it going well and have it in second with the key on and pop it (clutch). if that works and no fuses then check from there power cause it seems to me that you aren't getting consistent power to the starter if it pops or clicks.
Dave |
edit...just saw you got it after chads help...yeah he called me a while ago....glad you got it worked out.
Dave |
thanks and thanks for your help Dave {thumbup}
| All times are GMT -7. The time now is 07:32 PM. |
