How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
As always, no warranty expressed or implied - do this at your own risk. This is for offroad use only. The EGR is a required emissions component on vehicles where it was originally equipped.
How To Disable / Remove your EGR: Background: The EGR recirculates EGR gas from your exhaust into the intake to reduce the formulation of Nitrogen Oxides. Newer cars (evo X) prevent the necessity for this with modifiable cam timing that can reduce these emissions to acceptable levels. Note the location where EGR gasses enter the intake manifold as shown here: http://thefrost.net/randomfiles/rand...o/beforeIM.jpg The problem with this is 3 fold: 1. The EGR injects soot filled gases into your clean intake manifold getting it dirty and VERY hot 2. The EGR can open under certain undesirable conditions causing issues with timing / power 3. At higher boost pressures these lines often blow off creating a vacuum leak and robbing power as well as making idle rougher. 4. This will also reduce clutter around your intake manifold. (A more in-depth explanation of EGR functionality which I believe was quoted from somewhere else):
Originally Posted by lemmonhead
(Post 6647267)
The sole purpose of the EGR system is to reduce the formation of Oxides of Nitrogen (NOx). These are formed when the temperature in the combustion chamber reaches very high levels. To avoid this situation, the EGR system is used to lower combustion chamber temperatures by admitting small amounts of exhaust gas back into the combustion chamber. As you can imagine, exhaust gas does not burn, and does not help the combustion process. If the EGR system would admit exhaust gas into the combustion chamber at idle, it would cause a rough idle, or stalling. As a result, EGR does not allow exhaust gas into the chamber at idle (nor at wide open throttle, more on that later...). To accomplish this, there has to be some way of controlling EGR flow.
The way this is accomplished is actually quite simple. First of all, there is a round, flying saucer - looking part that mounts on the intake manifold. This is called the EGR valve. There is an opening in the intake manifold from the cylinder head that allows exhaust gas to move up to the valve. When vacuum is applied to the valve, it allows the exhaust gases to pass. To control when the valve receives vacuum, an EGR solenoid is used. This part mounts on the passenger side near the back of the intake manifold. It has a vacuum line which supples ported manifold vacuum, and another vacuum line running to the EGR valve. When the ECM requests EGR to be ON, it sends a signal the the EGR solenoid, which then allows vacuum to be applied to the EGR valve. When the ECM wishes EGR to be off, the solenoid will cease to apply vacuum to the EGR valve. The ECM will turn on the EGR solenoid by grounding it. It does this via pulse width modulation (PWM). This means that the ECM will turn on and off the solenoid many times a second. Just how many times this occurs will affect the amount of vacuum applied to the EGR valve, and therefore the amount of exhaust gas admitted into the combustion chamber. During the time that EGR is requested by the ECM, fuel output and spark advance are also altered. More timing is added, and the fuel mixture is leaned a bit. During WOT (wide open throttle), the ECM shuts down EGR. Since EGR will play no role whatsoever under WOT, it will not impede the engine's ability to generate horsepower. How does the ECM know if there is a problem with the EGR system? Well, the answer depends on what year TPI setup you have. If you have an 85-89 setup, then there will be a single wire that goes to the base of the EGR valve. This is basically a temperature switch. When the ECM requests EGR, it will check this wire to see if there is a change in temperature. If no change is detected, the ECM will think there is a problem with the system, and will throw a code 32. Most of the time, the problem is the temperature switch that is bad. However, you should first check for vacuum leaks, check that all vacuum lines are properly routed, check the harness connector at the EGR solenoid with a voltmeter, and make sure that the EGR passages are not clogged with deposits. The 90-92 TPI setups did not use a temperature switch on the EGR base. Instead, the ECM monitors the MAP voltage to determine if an EGR request was successful or not. When EGR is turned on, engine vacuum will lower a little. The ECM will throw a code 32 if it suspects that the EGR request was not successful. So what would someone gain by disabling EGR? Just about the only thing would be less parts under the hood. Basically, removing EGR gives you more space (although not much). To correctly disable EGR from your vehicle, you MUST at the very least, disable it in the prom. This is done by setting the minimum temperature to enable EGR to 151 degrees Celsius (maximum allowable temperature), and setting the minimum vehicle speed to enable EGR to 255 mph (maximum allowable speed). Since the engine will never reach either of these conditions, EGR will never be requested by the ECM. Since EGR will never be requested, it does not matter if you leave the EGR system all installed in its original place, or if you remove it from the car. If you decide to remove it, you will need an EGR block off plate to cover the hole in the intake manifold. If you simply remove the EGR system from the car, but do not disable it in the ECM, you will run into significant problems. You will likely run into detonation, the engine will run very poorly, lack power, and will probably run on the hot side as well. In addition, you will get a code 32 before running very long. If you recall from before, the ECM alters fuel and spark advance when it thinks EGR should be on. If no EGR flow is possible because you removed it, you will have a lean condition which will be further aggravated by advanced timing. What you will need: -An EGR blockoff plate (some people use the pop-can gasket method, but that is ghetto and blockoffs are $5 on ebay) -12mm wrench (and preferrably a torque wrench, 10mm socket optional) -2 Vacuum caps and preferrably 2 zip ties. -1 large vacuum cap (if removing evap canister also) -1 M8 x 1.25 bolt 16mm long and 1 M8 lock washer (alternatively since this is an uncommon size, you can get a 20mm bolt and add 2 M8 washers, preferrably stainless) Directions: 1. First locate the EGR valve. It is on the intake runner right under the throttle body and toward the engine. (see below) http://thefrost.net/randomfiles/rand..._Vavle_Loc.JPG http://thefrost.net/randomfiles/rand...ni_TB_Side.jpg -optional: Remove strut bar and UICP - this may not be necessary, but its always easier to work in an open environment 2. Remove the 2 x 12mm bolts on the top and bottom of the EGR Valve. When pulling it off, take care not to damage or lose the gasket. Take note of it's orientation for the best seal when re-assembling with the blockoff plate. Note there are 2-3 vacuum lines that will need to be pulled off the valve when you get it out. This go to the solenoid and you can simply yank them off if you are having a difficult time. -optional: Apply high-temp RTV to the outer edge of the blockoff plate. This is not necessary unless you lost or damaged the gasket, but will provide a sure-fire seal if allowed to cure properly. Unfortunately it will also make a bit of a mess, especially if you ever need to take off the blockoff plate again. 3. The new bolts are required because the actual EGR bolts are much longer since they pass through the whole EGR valve. The blockoff plate is only 1/8" thick. Line up the blockoff and gasket on one of the bolts (with locknut and washers if necessary). Place this over the EGR location on the intake manifold and turn toward loose until the bolt jumps the thread, then hand tighten a few turns. This ensures that you do not cross thread the bolt (see warning below). 4. Once bolt 1 is hand-tight (or at least threaded a few times) line up the second bolt (and lock-nut / washers) and again, turn out, then thread properly and tighten to hand-tight. 5. Get out your torque wrench and tighten both bolts to 20N/M +/- 2 N/m (15 ft/lb +/- 1 ft/lb) WARNING!! - when tightening the bolts, DO NOT OVERTIGHTEN. Your intake manifold is made of aluminum and will strip very easily! http://thefrost.net/randomfiles/rand...o/8f49e8bb.jpg NOTE: you do not necessarily need to do everything shown in this diagram. You can leave the FPR connected at connection B - L. 6. Pull off the 2 hoses on the top of the throttle body. (hose W and Y). DO NOT loop one of them around since one is pre butterfly and one is post butterfly. Properly cap them with correct-sized nipple caps. As always, it is recommended to zip-tie them to help keep them from being blown off under boost. 7. At this point, you can consider yourself done unless you would like to keep going and remove the solenoid and extra hoses (read: the right way). It's like a choose your destiny novel! ========== ==================== Additional tools needed: 1 x 5/16" vacuum cap 10mm Socket -Optional: Remove the strut bar to provide extra room for yourself (When re-installing, tighten all bolts to 44 N/m or 32 ft/lb) 8.
Originally Posted by Wicked E
(Post 6910950)
I found it easier to remove the strut tower bar to make it easier to reach back there. You'll need 12mm either deep socket or ratcheting wrench. There will be 4 bolts holding that gold vacuum plumbing to the intake manifold. You will then find the large hose coming from the driver's side. I had to cut mine because there was no way that thing was coming off the nipple without some serious force.
9. Remove the 2 bolts holding the EGR Solenoid to the intake manifold stay using a 10mm socket. It is located on the intake manifold stay (about the most inconvienient location). A universal joint or small wabble extender will help, and doing the optional strut bar removal will definitely help also. http://thefrost.net/randomfiles/rand...lenoid_Loc.JPG http://thefrost.net/randomfiles/rand...o/d3c7de27.jpg Optional: Place the check valve with the side that was connected toward the intake manifold VTA and the other end on the EVAP purge line that comes into the engine bay (the fat one where it would connect to the bracket). This check valve will allow vapors out while letting nothing back into the fuel system. This valve may become stuck closed and clogged if left open to air in a dirty environment, but this may be better than whatever clogged it having limited access to your fuel system. If you are planning on removing the charcoal canister do not do this step and see the note below about this check valve. 10.Cap the location for this line on the intake manifold with the 5/16" vacuum cap. Disconnect and remove the EVAP solenoid. ==================== ========== In the ECU: -XXX- See Mr Fred Quote Below, might be good anyway- Change Periphery 0 (FAA) bit 11 to 1 (to disable EGR Timing advance) -XXX- Not necessary if disabled correctly - Change Periphery 2 (FCA) bit 09 to 0 (to disable P0401 EGR Test) -XXX- Unrelated, but a good change for anyone with problems :p- Change periphery 4 (FEA) bit 14 to 1 (to disable MAP vs Baro test on startup - not necessary but doesn't hurt)
Originally Posted by mrfred
(Post 7272332)
Ok, after some more disassem of the EGR routines, I have found that Periphery 0 (FAA) bit11 does not actually shut off the EGR system until the coolant temp passes ~68C. Its ok to use if you plan on ripping out all the EGR stuff. However, it turns out that there is a byte length value that completely disables the EGR system and is a better choice to use.
For USDM Evo 8 94170008-15 use: Code:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/> Code:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/> For emissions: Update your OBDII tables to report "passed" for the EGR test. I will allow you to find this elsewhere. ========== ==================== ========== Alternative Method / Additional steps: (better but more difficult) Using this method should significantly reduce temperatures in the intake manifold. It will also facilitate the use of a Phenolic spacer which can leave your intake manifold cool to the touch. Without using this method you risk melting or deforming a phenolic spacer. This happens because you are not blocking the hole in the head before the very hot EGR gasses reach the intake manifold. Note the small port in this image where EGR gasses pass around the head and back into the intake manifold before the EGR solenoid. http://thefrost.net/randomfiles/rand...to/03_head.jpg
Originally Posted by tkklemann
(Post 7366179)
While I had the head off the car, I was poking around it and was trying to think of a way to totally block off the EGR port to keep the hot exhaust gasses out of the intake manifold itself. See, too many people worry about putting the heat spacers in between the manifold and head when it really doesn't do much because you still have 900*+ exhaust gasses inside of the EGR runner on the intake manifold.
Basically, to make a long story short, I pulled out my digital verniers and measured the hole diameter and it dang near came out to exactly the tap drill diameter for a standard old 1/8" NPT thread. So, I stuck my 1/8" NPT tap in there, and ran the tap in about 2". I ordered a stainless 1/8" NPT plug, and tightened it in there really good. It currently sits in the hole about 0.5" deep, away from the intake manifold mating surface. Since I have had it in there, I have put estimated 15,000 miles on the car, and every time I pull the intake manifold off, I check it to make sure it hasnt come loose. So far, no issues to report. It's really that simple. Measure your port hole (Because it is a cast in runner "tube" if you will) and as long as it is really close and not too big, then just oil up an 1/8" NPT tap and have at it. I would definately stay away from a brass plug though due to the heat. You technically could do it with the head on the car, and just vacuum out the port to get all the shavings out of the hole. It will work because the other end of the port is in the exhaust chanmber, and open to atmospheric pressure, so if you stick the vacuum on the hole it should get all your shavings out no problem. http://thefrost.net/randomfiles/rand...to/egrplug.jpg (Thanks to Scheides and his wife) ========== Additional information: If following the diagram above, you can remove the evaporative emission purge solenoid and evaporative canister as well. In doing so, you will remove 4-5 lbs from the car. You simply need to plug the port on the intake manifold, and vent the evaporative hose coming into the engine bay. The canister itself can be removed and the source hose to the canister vented as seen here: http://thefrost.net/randomfiles/rand...o/SDC10444.jpg The Canister should be on the driver's side of the car next to the gas tank / spare: http://thefrost.net/randomfiles/rand...al_can_loc.JPG http://thefrost.net/randomfiles/rand...1.DSC_0355.jpg http://thefrost.net/randomfiles/rand...2.DSC_0354.jpg Good / New method: Remove everything in this diagram except 15, 4, and 12. connect 4 and 12 with a 17mm barrel (one is 16.5mm and one is 17.5mm). Cap the hose for connection #3 with a 12mm cap. Note that if you do not do this there will be limited access to your fuel system via connection 2. Bad / OLD method: Remove all of this diagram after hose #7, and plug hose #7 with the check valve from the front of the car. Optional: Remove the hard line (#7) that runs from the rear of the car to the front of the car. Note: you will have to un-bolt the fuel brakets along the underside of the car and the line does not weigh very much. Optional: The check valve might be useful if you will be removing the charcoal canister as it will allow vapors out while letting nothing back into the fuel system (at connection #2 above). Unfortunately it is much smaller then this connection and the valve may become stuck closed and clogged if left open to air in a dirty environment, but this may be better than whatever clogged it having limited access to your fuel system. Please note the check valve is represented backwards in the image shown above, as well as some of the other FSM diagrams. http://thefrost.net/randomfiles/rand...can_detail.JPG Change periphery 2 (FCA) bit 15 & 14 & 13 to 0 (to disable EVAP checks if you removed these solenoids) Change periphery 4 (FEA) bit 07 to 0 (to disable FPS if you removed it also) (FCA bit 15 will also take care of this) Props to anyone who's pictures I didn't quote! https://www.evolutionm.net/forums/7036083-post82.html https://www.evolutionm.net/forums/7043356-post89.html https://www.evolutionm.net/forums/7052598-post93.html ------- UPDATE ------- Everyone please note that MA people who are trying to do this and street drive are having trouble with emissions. Please remember this is for off road use only! https://www.evolutionm.net/forums/no...refer-mac.html |
Nice write up. I did this on my prelude and will do it on the evo also.
Cleans up the engine bay nicely. |
any hp advantages from doin this?
Originally Posted by idriveanevo
(Post 7625725)
So you save a total of 5lbs?
Every bit counts.
And not if your tuned to have EGR and EVAP deleted. |
I did this on my car a couple months back and if I would've had this write up it would've helped alot :) Thanks for taking the time to do this to help others :beer:
Originally Posted by wizzo 8
(Post 7626552)
It is very common for the EGR lines to blow off and cause a major boost leak along with worse drivability. You can also use the EGR as a 3 port BCS. EGR gasses are also very hot and can melt phenolic spacers and get the intake manifold very dirty. There are alot of advantages, most of them are listed in the first post. One other benefit is that it creates some room for something under the rear of the car if you need it. |
anything bad that can come from doing this delete?
Originally Posted by D-Mon3y69
(Post 7626788)
....not really |
I guess I have a winter project
Originally Posted by fostytou
(Post 7627198)
Failed visual emissions check, clogged vent tube if you drive in really dirty/clay-y areas (can happen stock also), failed plugin test if you don't know what you are doing, possibly worse environmental effects from your car.
....not really |
so if i do this mod will it be like in a honda where you smell gasoline all the time?
great post!...thanks for this!!
Very detailed!
