plsatic pop-in screws in trunk?
how do you take off the plastic pop-screw things in the trunk that hold the trunk lining? Im trying to install a rear strut, but i want to know the right way to do it first.
http://www.sromagazine.com/home.php?op=view&id=862
try that. Also to roemove the grey plastic nubs I just used a flat tipped screw driver and pryed right out. The black ones you just push very lightly in the center and they will pop out pretty easy. |
Yup, just push in the center piece lightly and you'll be able to pull the whole thing out. Becareful not to lose the center piece.
you push IN on them???? I thought that they needed to be pushed outwards?
You have to push in on the center button to release it and then pop the whole assembly out.
