How to Remove Stock Factory Badge
Does anyone have an easy way or trick to remove the Lancer "Evolution badge" that comes with the car? I Just put on the Evolution VIII badge and I want to remove the stock one.
Thanks |
stock badge removal
use a hair dryer and dental floss, take your time.
all the residual glue, use a towel with wd-40 and whipe it off. ..hope this helps. |
Hey thanks worked well. Instead of wd-40 I used goo gone. Came right off:)
Now wax the spot where it was.
Already did. Looks great with just the Evolution VIII and the mitsu symbol:)
Hey just a quick newbie question.....is the Mitsu symbol just glued on also, i ask because everything on my car except for the Actual A is glued on. The A on my car is mounted by holes in the hatch
The :mitsu: symbol is glued on too.
ahh now I get it thanks alot dude
I swear I cannot find any goo gone! :(
Where did you get yours at? At autozone or oriellys they have no clue what I am talking about. |
Try Home Depot or Lowes or also try Goof Off
This is the procedure that Ive used on a couple of cars (some audis, some Vdubs, and a friends EVO)..
First.. I wash the car... Second.. I break out my dental floss (if its good for your teeth its good enough for your car.. right?) which I use to saw away the glue holding the badge up (if you don't have dental floss you can also use fishing line).. What I do is wrap some dental floss around my two index fingers and saw away the glue behind the badge.. Simple enough Third... With the badge off the car, I use some automotive adhesive remover to get the rest of the clue off.. I bought the adhesive remover from my local auto-parts store.. Fourth.. I rewash the area to get rid of all the adhesive remover.. Fifth.. I follow up with some Imperial hand glaze to clean up the area (and some clay bar if needed).. Finally.. I finish the area up with some blitz wax.. I don't use a heat gun or a hair drier simply because Im a little nervous about apply heat to the paint.. |
About how long to remove a badge?
Im new and I have read almost every post on this site.I just joined today.Anyways I work almost everyday and I want to know about how long it will take to remove a ES emblem.Thanks in advanced...
It shouldn't take too long. When I took my OZ badge off the longest part was managing to clean up all the glue from the back of the trunk (it could take anywhere from 2 minutes to 30 minutes depending on how much glue you leave on the trunk and what you are using to get the glue off). Hope it helps....
10 minutes is a safe bet. |
It took me 5 minutes maybe. Mostly just taking the time to heat up the badge. Also this goes in Lancer forums not Evo.
it takes u 5 minutes total including remove and clean up.
