Valve cover stuck
Trying to remove valve/rocker cover for gasket replacement but it won't budge. Any tips on getting it off without damaging the head. I've tried tapping it with a rubber mallet but still will not budge.
Make triple quadruple sure you have ALL the bolts out so you don't crack it. Once you do that, use a flat tip screw driver pry it up at the corners on the transmission side, it'll come off with a smidge of force. Stick the screw driver between the cove rand head and just turn it like you're turning a screw. A few spots on the gasket get silicone to prevent leaks, so the cover doesn't just come off.
I had the same problem. Try inserting a long bolt through the bolt holes securing the timing belt cover and give it a few light taps with a rubber mallet to get some upward motivation. Be careful, because when it gives way, it does it suddenly.
Originally Posted by cleong
(Post 11863014)
Handle with care, especially areas where the metal is thin. They are relatively brittle.
I solved it ages ago... By getting a screwdriver between the rocker cover and head and twisting very gently.
Good info for the next person. {thumbup}
