Repairing Damaged and Faded Carbon Wings
#32
Is there any chance that the warranty covers the parts that are replaced under that warranty?
Say my wing was fading and I got it replaced under warranty. It would come as no surprise if the new wing started to fade too. Even though you're over the warranty with miles, they know when it was put on and if it's withing the original warranty timeframe, think there's any chance to get it replaced again? I doubt it, but it makes sense.
My point is, if they replace a crappy part with the same crappy part, shouldn't you be able to get that fixed again? Meh. Even though my wing just got replaced, I just feel like it will happen to this one too. Why wouldn't it?
#33
Man, wish I would have seen this thread a few weeks ago. had a friend with "paint and body experience" refinish the top of my wing, but he left a few scratches that he sprayed clear over. any suggestions on removing the scratches? does the clear need to be completely removed again, or can it be sanded even with the scratches and recoated?
#34
If the scrathes are on the actual carbon fiber (below the clear) you need to do it all over. If its in the clear, use some 2000 grit wet sandpaper and then finish with a "fine scratch remover" rubbing compound. THIS works well to get 2000 grit scratches out real easily. Buff with a good wax and you'll be fine. Sounds like you'll need a do-over though.
Its all in the attention to details with stuff like this...can't rush it.
I just redid my wing:
#35
Krylon acrylic clearcoat in a spray can from Walmart . Did about 6-8 medium coats (a full can) waiting roughly 10-15 minutes between each coat. Let it sit for 6 hours and wetsanded it smooth with 2000 grit wet sandpaper on a foam padded block. Finished her off with the rubbing compound I mentioned earlier and waxed it to a nice shine (with UV protectant wax of course).
My wing has been delaminated for a long time (previous owner never fixed it) so I had some slight discoloration in those areas so i didn't go "all out" on my wing. I just wanted the clearcoat to look more uniform for now. Luckily, you can BARELY see the discolored areas.
#39
hey driftking, what exactly sandpaper and clear coat paint did you use to repaint? My wing is in bad shape right now, let me know where u get the sandpaper and clear coat, link please if possible! thank you in advance!
ps: you did a good job on your wing! btw your private message box is full
#40
I'm planning on doing this with my wing in a few days... it's in pretty bad shape. Probably won't look perfect when I'm done cause it's so bad but we'll see.
My question is... is it a bad idea to put the clear coat on when it's cold outside? It's in the 30s to low 40s around here now. If it's too cold to apply the clear... is there anything I can do to still get it done this week? Like use a light bulb or heat gun or something. Or would it be ok to sand off the clear coat that's on it right now and wait until it gets warmer out (spring time probably) to put on the new clear?
#41
If its below 60-65 degrees, dont bother. You won't get adhesion and you will waste a lot of your time. If you can bring the wing inside for a day, then quickly bring it outside and spray it, then bring it back in you just might get away with it. My clear is actually re-lifting so be sure to get a good quality clear coat and I would suggest to finish it with 400 grit before you spray it for better adhesion.
#42
Try to find a paint supply store, Like Bob's paint. They are all over the place. If not checkout the net, do a local paint supply store search... They will have your 3M sand paper and the things you will need to get the job done right.
Start with a 600, then once all the old clear is gone switch to a 1200. For clear coat go with Dupont Chroma clear. It's expensive but you get what you pay for....really good clear.
#43
Yes bad idea to paint when it is cold, or humid.
Remove the wing, do it in your garage. Use a space heater to get the room temp to around 75-78 degree's depending on the gun your using and how much is sprayed between flash time.
#44
For all you Rustoleum and Krylon users....
Get ready to do them all over again in a few months, maybe a few weeks.
First sign is the white cloudy look.
Spend a little money and buy the good stuff. Go buy a cheap gravity fed gun at Harbor freight. Most of you have access to an air compressor. Put an inline filter for clear air..done.
