Air Dam Extension reinstall
I removed the rubber lip (part of zero lift kit) from my car a while ago for clearance reasons and now I'm moving to a new place with a decent driveway. Now I can't remember how this was attached at the factory, can someone scan the install instructions or tell me where the regular and split washers go? Also, I have two strips of stainless in addition to the one embedded in the extension. One strip is wide and obviously goes in the middle. THe other is only about 1.5" long. WHere does this one go?
TIA
-n.
TIA
-n.
it installs on the plastic lip of ur under tray. the long strip of stainless goes in the middle and the two small ones go on the two screws on either side of the middle strip. the flat washers go against the plastic and the split washers go behind them before u put on the nut.
http://www.ne-evos.net/data/2003serv..._starthere.pdf
this is the service manual
lip extensions pertain to the se zero lift kit of an 06 ix
good link though
Touge Factory
Nov 23, 2013 10:36 AM
thomas_herrera
May 24, 2005 06:33 AM
