how to remove side marker
Old Oct 12, 2008 | 02:50 AM
anton406's Avatar
how do you remove the side markers in your evo? thanks!
Old Oct 12, 2008 | 06:43 AM
itzcharlez's Avatar
you push them toward the front of the Evo and then pull them
out from the wider part.
Old Oct 12, 2008 | 06:47 AM
evokel's Avatar
a flathead screw driver and a cloth and pop it outwards
Old Oct 12, 2008 | 06:59 AM
mitsumanny's Avatar
the way i did was jack the car up then just remove some of the clips holding the fender shroud so that u get get ur hand in then just pop the markers out from the inside of the fender. U should be able to feel the clip. took less then a minute plus u dont have to worry about the screwdriver on the body. jacking the car up was just to have more room to work with but its not necessary.
Old Oct 14, 2008 | 07:50 PM
YearOne's Avatar
Take a strong fishing line and slide it behind the marker from the rear and pull forward to undo the clip. That's it.
Old Oct 16, 2008 | 09:23 AM
pjb00stin's Avatar
thats doing way too much..
you dont even need a screw driver,just push forward and pull toward you.thats it
seven10
May 6, 2017 05:04 PM
LancerEVOVIIISD
Sep 13, 2016 07:59 PM
EVOIXSE
Jun 18, 2016 12:25 PM
HondaTuner
Oct 14, 2014 05:06 PM
CR7-Style
Feb 27, 2008 07:19 PM
