ams uicp w/ factory bov ?
I don't know what the deal is:
1. I a missing a part with the stuff ams sent
2. I am required to buy my own part
3. I installed the piping wrong.
help please!! ideas welcome
here is the pic
the oem hose won't reach to bov. and I am sure that I don't have an oem pieces that I may have removed prior to this install.
here is the pic
Ams Uicp
1) The Hose doesn't fit because you have the UICP/w the Mini Battery set-up, the hose is only made to fit the UICP Stock Battery set-up. (see picture below)
2) Either Call AMS and ask if they sell this hose separate or try Autozone or any other automotive store.
UICP /w Stock Battery
http://www.extremeturbosystems.com/p...ID=163&image=4
2006EVOIXMR,
Why don't you do research before you post misinformation. If you'd bother to check AMS' website, you can see that their UICP REQUIRES a small battery kit. They don't sell one for use with the stock battery because it is a short routed UICP.
Dude you really need to read before you post misinformation.
yea figured it out..
went to pepboys and bought an 11$ coolant hose for some car that was bent like I need it to be bent.
I need to email AMS about this. I believe they should supply this part or at least have it in the description what you need. I hate to stop in the middle of something to run to the store... good thing I have a daily...
sorry you had so many problems. We thought about adding a custom silcone piece to this but it would raise the price. Also we were finding many people would not even recirculate it. Although we don't recommend that it was pretty common. Also some that were installing it were changing the BOV to mount in the IC pipe instead of the way it was from the factory. With all that in mind we thought we should simply omit a pipe. I do see where you are coming from in not mentioning it though. I will change the site and the instructions to note that. Thank you and sorry for any misunderstanding.
Eric
Eric
Eric
Eric
Care to share what model number or car you got it from?
just go to pepboys,, tell them you need radiator hose...
they will let you back there to look.. just get one that has a 90 degree bend then is straight about 12" I cut mine a lil.
