How to: Replace OIL LINE??
Old Mar 15, 2009 | 09:50 AM
Nomad4g63's Avatar
Well i bought myself an FP RED not too long ago, and just now i see online that it is strongly recommended to replace the oil line. So i just bought the FP RED oil line with filter http://store.forcedperformance.net/m...Lancer-TurboHW
and need to know how to install it?
Old Mar 15, 2009 | 09:46 PM
Nomad4g63's Avatar
anybody?
Old Mar 16, 2009 | 11:03 AM
Boltz.'s Avatar
FCOTM Winner
Very simple. The oil feel line is at the top of the turbo. It connects to the right side of the head.
Unbolt the first bolt from the head. Don't drop the copper washers and put them aside with the bolt removed from the head.
If you're a dirty gear head like me, you can hold your hand around the tube and try and blow through it so that it doesn't leak like crazy when you remove it from the turbo.
Unbolt the oil line support from the turbo, (10mm) then unbolt the feed from the top of the turbo (17mm or something like that). Then, simple reverse the steps and put the new one on. The filter will be closer to the head than the turbo....
Old Mar 16, 2009 | 01:35 PM
SICK9's Avatar
Thanks,
I just put my RED on yesterday and I need to do this also..
Seems easy enough.
Old Mar 18, 2009 | 10:39 PM
Nomad4g63's Avatar
that right there. to try and take out that 10mm oil line support is hell and a half. Very hard place to try and get the bolt out. Other than that everything else is fairly easy and simple. Just @ the moment i dont know which way to route the longer braided hose i got from FP. I dunno if through the back where the block is or through the front.
Old Apr 20, 2009 | 05:34 PM
sk8terdude929's Avatar
I am trying to install a loil feed line now and it keeps leaking, it had 2 copper gaskets (1 on each side of the banjo bolt) but everytime i tighten them down and start it up it is leaking like hell.
Any one know if there is only 1 copper crush gasket or 2 to install on the oil feed line?
My03evo
10
Mar 11, 2016 07:17 PM
Aniel
Feb 5, 2016 07:08 AM
OakosAutomotive
EvoX 'For Sale' External Engine / Power
41
Aug 16, 2013 12:47 PM
addo
13
Apr 3, 2010 07:59 AM
Evo9tunerz
Dec 26, 2009 12:31 PM
