HKS type 1 help for evo 9
Old May 15, 2011 | 03:06 PM
Evilution23's Avatar
ok so i hooked up my turbo timer. blue with the black and yellow wire for the speed (mph) and brown with brown and green for the rpm. I tried to do the rpm learn and it won't register rpms and wont read. i tried to rewire it and no luck. should i wire it right at the crank sensor connector right behing the valve cover or is there something else im missing. Also sometimes when i pull up the ebrake and have it on the timer setting when i shut off the car it doesnt run and the car shuts off when the key is off right away.
Old May 16, 2011 | 04:45 PM
anyone
Old May 17, 2011 | 01:59 PM
prs0303's Avatar
Sounds like you might have the brown wire hooked up wrong. If the E-brake wire (Should be brown) doesn't see ground (aka when the e-brake is up) then it wont let the car continue to run because it thinks the e-brake is down.
Try grounding out the parking brake wire. It's cheap way to bypass it but it'll at least let you know the parking brake wire is doing it's job...
Old May 20, 2011 | 03:43 AM
cowboy14's Avatar
I am agree with prs0303
Old Oct 26, 2012 | 11:10 AM
03nevaevolution's Avatar
Veteran: Army
well my issue is similar but not the hook up. i hooked it up with no issues(even the rpm sensor). then my car was broken into and the steering column where the unit sat was torn apart and now it doesn't work. i have gone over ever wire and ground with no luck!! any advise other than get another one?!!
beast66
Feb 15, 2016 12:51 PM
LaFuriaRoja01
Dec 28, 2013 08:15 PM
Frew
Nov 18, 2013 05:50 PM
mercsan
30
Dec 5, 2007 06:55 PM
gbwaacha
Oct 13, 2003 11:17 AM
