Front Lower Control Arm Install
Old Jun 8, 2011 | 03:49 PM
RSGuy's Avatar
Hey guys,
I need to replace the front lower control arm. I need some instructions on how to remove the arm from the knuckle. I searched but couldn't find any help with this. Somebody help me out? Thanks
Fred
Old Jun 11, 2011 | 01:20 AM
Hendrixmx's Avatar
Just replaced mine last week. The ball joint is connected to the knuckle. Just have to take out the bolt holding the spindle of the ball joint, and it should drop down pretty easily if it's not to corroded.
Old Jun 23, 2011 | 06:03 AM
jgrotkier's Avatar
I just had this problem last weekend (on top of having the inside bolt complete seized to the collar inside the bushing.
Buy this set: http://www.harborfreight.com/hand-to...-set-1654.html
Take the biggest bar and jam it between the LCA and Knuckle (careful not to rip the boot) and bounce it up and down a few times. It'll come out.
Old Jun 23, 2011 | 05:33 PM
Hendrixmx's Avatar
You can also give the knuckle a few really hard whacks, and itll come right out
Old Jun 23, 2011 | 07:45 PM
the mark w's Avatar
17mm bolt goes through the spindle.
19 or 21mm bolt that bolts through the flca into the chasis.
then the last bolt i have no idea what size cause i forgot. im assuming 17mm
just unbolt it all. pry between the spindle and flca to release the ball joint.
then work the damn thing out, sometimes its a pita most the times its not.
overall if you know how to use hand tools. you will be fine.
Old Jul 3, 2011 | 03:05 PM
aznsyco's Avatar
whack it!!
Old Jul 5, 2011 | 10:45 PM
IbeBOOSTIN's Avatar
Originally Posted by aznsyco
whack it!!
x2 lol
Old Jul 6, 2011 | 05:24 PM
2slow4now's Avatar
whack it!!
It might not hurt to pre-lube the bolts too since your going to whack it.
El Boricua
Jul 13, 2015 07:23 AM
martinPL
For Sale - Part Outs
Jun 27, 2015 08:23 AM
hachansoo0413
Jun 21, 2012 07:19 PM
lbegorre
Oct 11, 2011 07:40 AM
polish_pounder
14
Aug 20, 2011 12:43 PM
