Walbro 400LPH Fuel Pump Modification
#31
im pretty sure once you rewire its gonna overrun the stock fpr. my customers installing this pump tomorrow in his evo 9 not rewired so will get some data with it not rewired and see how much power it can support on e85 with fic 1550's. he only needs around 550 since hes still on stock block.
#33
I would recommend removing the fuel pump hanger assembly and checking over the install.
Make sure that the black rubber seal that goes on the fuel pump outlet is fully seated in the housing and that there are no tears or damage of any kind.
Check to be sure that the o-ring that is under the black plug on the side of the fuel pump housing is properly seated.
Check to be sure that the hose clamp around the fuel pump is not overly tight, which can distort the fuel pump housing and cause issues.
#34
just a question i've read on other threads that you need to use a 255 sock rather than the 400 sock as the 400 doesn't fit.
in the pictures i see people using the 400 sock, so just wondering does the 400 sock fit?
Also any chance of anyone with a picture of the tabs your supose to trim?
#35
Dan (drb)
#36
thanks guys that makes things clear for me now.
Anyone having any surch issues? i was speaking to my mechanic and he siad the 400 might have issues with surge as the return may not be big enough to handle fuel return at idle?
Anyone with this issue?
#38
ok. i just did this install and re-did it 3 times. my car fires up but dies right away . if i hold the gas pedal down and keep it above 2k rpms the car will run (anything lower and the car stalls again, holding down the gas pedal or not). before the car dies though, my wideband goes full lean.
me and my buddy disconnected the fpr and put our finger over the outlet of the fuel rail and bumped the engine to see if any fuel is being pushed out, and since i think our fuel pressure is set somewhere around 43psi , fuel would squirt out everywhere trying to push my finger out of the way right? nope.
no pressure in the fuel lines and very little fuel buils up.
we rechecked the install and i dont get it. anyone have any problems? or suggestions? someone commented on having to remove the bottom braket altogether?
#39
Check the pump where the hose connects to the housing. I have seen them either split or the oring not seat properly. I have no experience with the 400, just some issuies I have seen with other pumps.
If you can hear the pump hum, then its either not getting fuel in past the sock, or not getting it to the lines.
#40
someone mentioned we're supposed to use the sock from the 255 on the 400? is this correct? we inspected the lines coming away from the canister as we start the engine. nothing leaking. also should point out that we tried putting the my old 255 back on and we get the same problem.
#42
just thought id point an update to my situation and for those who have trouble in the future. there is a magnet built inside of the housing that im assuming (someone correct me if im wrong) allows the return fuel to enter the tank and stays open as long as the car is running.
for some reason the magnet was staying closed so we tapped it a few times with a small hammer and reinstalled the pump and hooked everything up and the car is fine now idling perfectly.
#44
just wanted to add some input to this thread as i had questions before i installed mine. i cut mine the way i saw in AMS's thread. and put a clamp around the pump (not very tight though). I am just running the standard 255 kit. no hardwire. on stock fpr, and rails, and everythings working fine. make sure before you start cutting you put the seal and stuff on your old pump and push it all the way in so you can see how it feels when the pump is properly sealed. then cut it as close to the top tab as possible to make sure you dont go down farther than needed. then push pump in to where it locks in. I used the bigger filter that came with the 400. i've seen on someones thread where they used the smaller filter and they were able to retain the cap. i guess that would work too but it seems like more work and it makes more sense to use the brand new bigger filter vs an old filter that may be clogged up. if it locks in it's the same height as stock, and the clamp will keep it from sliding down and you wont have any issues. just my 2 pennies. currently tuning with tom. will let you know how much the fuel system will support when alls said and done.
#45
also one more thing. i dremeled the part of the pump that the "ring" and the seal go on. and then had to go down even farther because the ring wouldnt go on. i learned that you can easily cut it with a razor blade and it will be much less messy. and there will be less chance of the dust getting inside the pump. also be patient with putting the ring on. i tried to force mine on and i broke it.
