transfer case going bad?
Old Nov 19, 2011 | 01:12 AM
repairmanevo8's Avatar
Hey guys I just bought an 04 evo with 72600 miles. Its in good shape besides the whine it makes. It makes a whine when moving. Not loud at low speeds but the higher speed the louder it gets. Eventually it levels off to a certain loudness. The noise on exists when accelerating. When of the gas or deceling the whine completely dissapears. Any thoughts? Thanks guys
Old Nov 19, 2011 | 01:01 PM
todd6027's Avatar
sounds like transfer box bearings on the way out check crown wheel and pinion shaft for wear also.
tr box oil will be a silvery color
Old Nov 19, 2011 | 06:39 PM
Alright thanks guys, so the tc itself is alright just need to check is the crown wheel and pinion for play?
Old Nov 20, 2011 | 05:32 AM
todd6027's Avatar
as bearings wear the pinion preload and c/wheel to pinion backlash alter causing wear on the gears . replacing bearings with worn gears and you will still get a whine.
Old Nov 20, 2011 | 08:12 PM
out of curiosity, what would happen if i didn't fix the whine?
Old Nov 20, 2011 | 08:30 PM
marcusE's Avatar
I've got the same whine did you happen to test drive it with that noise before buying?
Old Nov 20, 2011 | 10:55 PM
EvoSportz's Avatar
try filling full synthetic oil into transter case
i had a wrx while back tranny was making noise full synthetic oil fixed the problem.
Old Nov 21, 2011 | 12:12 AM
Yeah I test drove it before buying it. The guy had his friend along that workes at atlantic motorsports in maryland where all the work was done to the evo. He and the seller both told me the cars had the whine for about two years now. Guy that built it said if you don't mind the whine, its not going to hurt the car. I didn't believe that tho, whitch is why im here. For the price I payed tho I couldn't pass up the deal
Old Nov 22, 2011 | 10:34 AM
marcusE's Avatar
I'm afraid to sell mine with the whine dont wanna look shady on the test drive.
Old Nov 22, 2011 | 10:40 AM
DontStopMe's Avatar
Originally Posted by Jacks Transmission
If your t-case is whining STOP and get it rebuilt! If you do not rebuild it now and you wait for the gears to break you can then burn up the VCU or ACD LSDs and be out even more money! The center diff LSDs are very expensive and hard to find! The pic below is of a broken pinion due to a person that ignored the t-case death whine noises:.
quote above is from Jacks Transmission site. While what they say is a concern, I had an evo with a whiny TC and put over 10k miles on it with no issues other than the damn annoying noise. I would have fixed it sooner if I could have afforded to.
But you have an 04 so no ACD?
Old Nov 22, 2011 | 11:01 AM
marcusE's Avatar
I have an 03 and I've put about 3k miles on it so far.. Just noisy..
so no acd for me as well.
Old Nov 22, 2011 | 12:53 PM
deylag's Avatar
I have an 05 RS and I can hear every noise the Evo makes. It whines all time but the TC fluid is clean everytime I change it. It only gets a little brownish not silvery.
Old Nov 22, 2011 | 03:14 PM
you right, i have to acd. I guess what my main concern is should i have it rebuilt? i live near williamsport, pa. if it needs rebuilt, where should i have it done?
Old Nov 22, 2011 | 05:54 PM
deylag's Avatar
My suggestion is that if you use this Evo as your daily driver replace the t-case if you have the money. If you can drop the tranny and replace the t-case with your own tools and this takes much of cost out of the job.
I also suggest that you upgrade the front diff while the t-case is out. It will improve handling, reliability, and power delivery.
If you keep driving the t-case till it eventually gives out you might destroy the core and then it will cost more because you will have to buy a new t-case.
Old Nov 22, 2011 | 09:59 PM
yeah I can drop it, do you know where and how much it costs for a rebuild?
