Starting Motor - 1st time in 2 years...
Old Jan 24, 2014 | 11:49 AM
steve-o411's Avatar
Hi guys
So my car has been on blocks for quite a while, well since March 24th 2012 - nearly 2 years to the day since it was last running...
Had been doing a number of things to it as well as other life priority's etc
Anyway the day has almost come where its ready to turn over so I can get it tuned etc. Just need to wire my air intake sensor for the Power FC D Jetro ECU
What should I do before hand to make sure there's no damage in the initial start up? i.e new oil/fluids, crank it over to get oil & fuel pressure up first etc? and idea it it will run ok i.e drive off boost until I can drive it to the tune shop (not that far away from me) and if the FC will even start up with 880cc injectors?
Cheers
Old Jan 24, 2014 | 01:46 PM
DSMdynamic's Avatar
Check out this thread, might help you out
https://www.evolutionm.net/forums/ev...ecautions.html
Old Feb 1, 2014 | 01:51 AM
jdm_dc_fan's Avatar
i would never be able to wait 2 years to drive my car.
Old Feb 6, 2014 | 08:58 PM
DiamondEvoIX's Avatar
Definitely fluid flush with all new fluids, new oil, replace filter, check air filter, make sure everything is secured tightly. I would not recommend getting on it at all until a tune is done. Just be cautious and not drive crazy till your tune is on and your engine is broken in.
Old Feb 15, 2014 | 07:40 PM
JaYr_EvO9's Avatar
i installed a 3.5 in front mount 1050cc and 255 walbro fuel pump i drove it to my tuner shop 20 min away i just stayed off boost and keeped an eye on my gauges like air fuel ratio and you should be fine. Also pull over if need too don't try to make it just because your almost there
Old Feb 16, 2014 | 06:30 PM
steve-o411's Avatar
Yep I know not to get on it until its tuned.
I'm more worried about stuffing the bearings etc. Its got all new fluids/filters put in it so that's not a prob as well as fresh gas.
Is there any chance the injectors/fuel pump/lines etc could be rusted or corroded? Ive heard of the this occurring. Its been in a dry shed and garage the whole time and the tank has been drained/empty the whole time.
Im going to crank it with the plugs out and fuel pump disconnected to get oil pressure up to make sure all the bearings are lubed up, then prob crank it again with the fuel line to the fuel rail to off to make sure no little bits make it to the injectors. Prob being a bit **** but don't want anything to go wrong.
What else should I look at?
Old Mar 16, 2014 | 11:14 AM
Sweeeeper's Avatar
Just do it!
Old Mar 16, 2014 | 11:15 AM
Sweeeeper's Avatar
As long as u biult up the oil pressure and fuel pressure before u start, u r good to go.
haxr303
Jul 3, 2016 07:50 PM
EvoVIIIFL
Oct 9, 2014 08:16 AM
Kc2Buk
61
May 5, 2006 11:39 AM
pyrovice
Mar 31, 2005 04:56 PM
