Alternator/Water Pump/Intake bracket
Old Mar 3, 2018 | 03:13 PM
jmrussell89's Avatar
Veteran: Air Force
Hey folks...the car has been taken apart for a while, and I've gone back to work on it.
However this bracket pictured here will not go back on whatsoever, line up, etc.
Sorry for such a novice question, but is there some trick I'm missing? I'm looking through my service manual and there's no steps for it or warnings like "don't remove this while there is tension on the belt."
Could I have messed up here by removing the bracket during a IM install or am I just totally missing something?
Thanks.
Old Mar 3, 2018 | 05:05 PM
Veteran: Air Force
To clarify, I didn’t use a spacer or anything. When I say it’s not lining up, it’s really really off. I took out the IM just to see and it’s baffling me.
Not the best picture but you can see that there’s basically no play there. It hits the water pump well before it can line up with the alternator.
Old Mar 3, 2018 | 07:42 PM
Veteran: Air Force
SOLVED!!!!
To those having this issues, especially after taking time to get a ported IM back, etc...what had happened was the alternator (with tension on the belt) had shifted clockwise on it's axis towards the front. I relieved tension from the belt (http://www.joe250.com/cars/evo8/belt...ltremoval.html) (this is the same for the 9), and pushed the alternator back.
I then proceeded to bolt the bracket to the alternator, and reapplied belt tension which seated the alternator to the other bolting points correctly. Hope this helps someone in the future!
Old Mar 4, 2018 | 06:22 AM
Tuxevo's Avatar
Nice work and good job posting your solution.
nor11384
Apr 29, 2017 09:25 AM
honki24
Sep 15, 2016 09:05 PM
Evilawd100
62
Mar 25, 2013 08:53 AM
bambooi
13
Nov 11, 2011 07:16 PM
bambooi
Aug 25, 2011 03:38 AM
