Cooling unit’s seal dripping water inside
I am new evo3 owner. I finally found where the water comes inside my car. Behind glove box is black box called cooling unit. Right side on it is grey seal and it is wet. Why? What i need to do and where? Thanks a lot!
I didnt find anything like that.. Should i go look bottom of the car? Is it easier to find there? I have problem to get there but it could be possibly to get car up with a lift..
The drain is rubber usually with a duck bill end on it and comes through the firewall towards the center of the car behind and slightly above the subframe. Even if connected correctly it could be plugged. Dirt over time gets in there. I once owned a Pontiac with a plugged A/C drain and crawled under without raising the car - I was slimmer then - lol. Nearly pinned under the car I stuck the wire I had with me up the drain and got a quart of very nasty water in the face.
It should be very easy to discern whether it is coolant (a leak) or water (condensation).
You said you found the external drian and it was OK, did you check it for blockages?
