Evap system removal, Need help!
I believe it is the evap system that is in the rear left corner underneath the car.? I was looking for someone else that had already done away with all of this. I do not have to pass any smog tests, so that is not a worry. Just looking to get rid of some stuff i do not need. Thanks in advance!{thumbup}
On the drivers side rear quarter of the car is the a section of the Evap system. There is a charcoal canister, vacuum solenoid, various hoses connecting to the fuel tank and fueling neck.
Ive just removed to the CC and solenoid to inspect and troubleshoot. Not sure what you would need to eliminate it. Might ask some serious drag racers what would be involved and if you would need to do anything to ensure the fuel tank was working as designed. When you remove the stuff go to the thread in my sig and sell me your stuff so I can fix my two codes {thumbup} |
More info?
I would like to know more about this too. Is there a downside? What is the best way to do this?
Never mind. I found it.
