How to: Radiator fluid flush & coolant flush
1 Attachment(s)
Haven't flushed your cars cooling system in awhile? Here's a brief how for Coolant flush and radiator drain.
TOOLS NEEDED: - 10MM WRENCH / 10MM DEEP SOCKET(OEM radiator) - DRAIN PAN - 2 GALS OF DISTILLED WATER - 2 CONTAINERS OF ANTIFREEZE(W/ FUNNEL FOR LESS MESS) - JACK + JACK STANDS The plug is on the BOTTOM of the radiator(see fig.A), on the passenger side. Jack up car and you will see only one opportunity for a 10mm hex. DISCLAIMER: PLEASE DO PROCEDURE ON COLD OR WELL COOLED DOWN CAR, PREVENTS BURNS FROM HOT COOLANT!!! FIG.A: Attachment 296858 Step 1: Jack up car with Jacks and jack stand, just do passenger side. Place drain pan under drain plug, loosen plug until fluid comes out(you might want to open fill cap on top of radiator first, releases vacuum in radiator). Continue to drain until it stops, just like an oil change...drip drip.......drip.......................drip :p Also drain and clean the coolant reservoir. While draining the radiator take the time to clean it, and have it ready with fresh fluid. Super easy to take off...2 bolts 10/12mm I believe, disconnect hose attached. Step 2: Once old fluid is out, get gallon or 2 of distilled water(depending on how many flushes you do) and pour into radiator fill cap from top of. Please make sure drain plug is closed. While filling the radiator you should run the motor and crank the A/C on Heat; max temp. Continue pouring till radiator is full. Step 3: Drain radiator again which should have a slight mix of left over coolant and majority distilled water. If you feel you got all the old fluid out then continue to step 4, if not repeat from Step 2. Step 4: Radiator should be fully drained of the distilled water, time to fill up the car with your preferred mix of coolant to water. Depending on what climate you live in, you can play with the mix of coolant : water. Drain plug for radiator should be closed and tightened. Remove drain pan, and lower car to level ground. Step 5: DO NOT FORGET TO FILL RADIATOR. Do it with the car on the ground and also refill Reservoir Tank. MAKE SURE TO CHECK FOR LEAKS BEFORE DRIVING OFF!!! Step 6: BURP system after filling radiator and reservoir. To burp system remove radiator cap on cooled down or cold engine(radiator should be full of fluid) start car and let engine idle. It may take a few minutes at idle for the air pocket to find it's way out. Initially the fluid will pulse and then start to pour over the fill neck. Once you're satisfied, replace lost coolant and clean up mess. Side Note: Make sure you are Checking your radiator fans for proper operation. If you have evoscan you conduct a quick fan test to make sure they are operational. I had one of my fans go out on me and didnt know it. |
nice, comprehensive how to do
kudos! will be doing mine soon, have all I need already |
Does the undercarriage crap need to removed to get to the drain plug?
^ Yes...good ol' plastic screws, have fun : ) ...i keep undershield off.
Originally Posted by Evoryder
(Post 7074981)
as do I, great job bro. |
Hi there
Great, Im due to do this and wasnt sure where the drain plug was for the radiator Just a couple of questions though 1. I noticed you drained everything whilst the car was jacked up (i.e. it was not level). Would it be better to jack up, drain, then let the car down to drain all its fluid whilst level on the ground, and then later jack it back up once you need to (to bolt up the drain plug again) 2. You mentioned just to refill the radiator and away you go. Do these cars require bleeding to ensure no air pockets are in the cooling system i.e. fill it all up, leave the radiator cap off, turn the car on and leave it there to reach operating temperature, wait for the thermostat to open so you know its reached the correct operating temperature, and wait for all the bubbles to come up to the top (where radiator cap would go) and watch them start to pop/bleed out of the system. then wait for no more bubbles, quickly put the radiator cap back on. This is what I was taught with an old car from the local mechanic Any thoughts? |
You don't need to drain it level, by running the distilled water through it will allow you to get the old fluid out.
Second question: You can do so if you want, but I don't believe it's necessary. |
Nice write up!! Need to do one soon.
What types of mixes are people running? Does water work the best?
I'm in miami, my mix is 70/30(coolant/distilled water)
I was thinking some water wetter until it starts getting nippy out.
(Post 7106858)
no and actually i am running 60/40...i was thinking of another car. 60% coolant 40% water
Make sure u get all of the air pockets out. If not under pressure u can pop a freeze plug. FYI!
Bringing the thread back alive. So about how much of each item would give you 60/40 is it 2 jugs coolant and 1 gal distilled water?
