E-brake not keeping car in place.. How do I fix this?
Hi I was wondering what needs to be replaced in order to have my e-brake work properly. On my last car when my e-brake went out I just had to replace these springs but I can't figure out how to do it on my evo? Please help and thanks!
Search is your friend:
https://www.evolutionm.net/forums/at...old-ebrake.gif If this adjustment doesn't fix it, the internally expanding drum brakes on the rear might need replacing. This is not common unless you often forget and drive with the emergency brake on. |
thanks! im not to sure what the cause was but it was like that when i bought the car last year and it has been in the build stage up until last month so i am just getting around to fixing the small things, but thanks again for the help!
Have you tried adjusting the cable under the center console?
Originally Posted by usacchamp
(Post 8602846)
well i took the console out and when i would pull the e-brake all the way up there was still a little slack in the cable so i adjusted the nut just barely and now the e-brake works fine so thanks for all the help!
I love these diy! Sorry stealership, I will be doing this tonight!
Good fix
For anyone else if adjusting doesn't help you'll need new shoes
Any how-tos for the rears?
