-   Evo How Tos / Installations (https://www.evolutionm.net/forums/evo-how-tos-installations-82/)
-   -   Help: Torque Solution 6-speed shifter bushing doesn't fit (https://www.evolutionm.net/forums/evo-how-tos-installations/742764-help-torque-solution-6-speed-shifter-bushing-doesnt-fit.html)
TheRealDirtyDan Aug 21, 2017 04:55 PM
Hey guys. I bought the bushings on the title online from STM. The bigger bushing that goes on the lower end fit fine, but the thinner bushing that goes on the top end is too tall and covers up the hitch pin hole, and it's just a bit too wide that the cable doesn't slip right over it. I thought maybe it was a manufacturers defect so I contacted STM and they were really cool about it and sent me a whole new set. I received it today and it's the exact same bushing. Anyone have any ideas?
https://cimg5.ibsrv.net/gimg/www.evo...1560e0aceb.jpg
No debris that would cause the bushing to sit higher than it's supposed to.
https://cimg7.ibsrv.net/gimg/www.evo...b855077a2f.jpg
Bushing covers where hitch pin goes through, and inner hole looks too big allowing play in the cable movement
https://cimg8.ibsrv.net/gimg/www.evo...6c429a074c.jpg
Shifter bushing diameter is too big and doesn't allow cable to go over it. I'd have to press it in.
https://cimg1.ibsrv.net/gimg/www.evo...923ac25d11.jpg
Shifter bushing doesn't fit inside cable.
4b11slayer Aug 21, 2017 05:45 PM
It looks like you need to remove that gold ring. Its like a bearing race. You see what im talking about? It looks like removing that will give you that extra room your needing.
TheRealDirtyDan Aug 21, 2017 05:59 PM
Oh that's not part of the cable? :o
But that wouldn't help with the bushing being too tall and covering up the hitch pin hole
4b11slayer Aug 21, 2017 06:04 PM
The pictures look like it isnt. Are both bushings the same size?
TheRealDirtyDan Aug 21, 2017 06:25 PM
No, there's a shorter, but much wider bushing that only fits into the lower cable.
TheRealDirtyDan Aug 22, 2017 10:44 AM
Anyone else?
TheRealDirtyDan Aug 25, 2017 09:38 AM
Update: they sent me the wrong one twice. Correct one on the way.
4g63 16g Aug 31, 2017 11:03 PM
Thanks for this I ordered the same thing for my 6spd and had the same issue.. I'll give them a call...
TheRealDirtyDan Sep 1, 2017 05:50 AM
Glad it helped.
Contact Torque Solution themselves though. They explained by email that the person in charge of packaging must have been putting the 5 speed bushing into the 6 speed packages. STM didn't catch that and sent me the second, wrong package. Torque Solution will send you the correct package free of cost
