How-to Swap S2K Cluster into Evo (Updated)
Decided to remake this thread so you guys wouldn't have to sift through pages of rambling to get what you needed to know.
You're welcome. Basics of what you'll need: -S2K (AP1) cluster -S2K cluster harness -Ktuned S2K dash converter -Wire stripper -Wire crimps/Crimper tool -Soldering iron w/flux core -Heatshrink -Some way to label your wires, not needed but it helps. -Any other basic wire working tools you'd usually have. -Patience. I have very little wiring experience and managed to faniggle this thing into functioning. You can too. https://cimg4.ibsrv.net/gimg/www.evo...db4945476.jpeg https://cimg5.ibsrv.net/gimg/www.evo...b87e3673e.jpeg https://cimg7.ibsrv.net/gimg/www.evo...3321d7e28c.jpg After you've gathered all of this you can get to work with the wiring. I went through the effort of finding and compiling the pinout info for the S2K cluster here for you guys so you aren't going through the pain and agony of finding it on Google or wherever. https://cimg8.ibsrv.net/gimg/www.evo...110c1a865d.jpg https://cimg9.ibsrv.net/gimg/www.evo...2555b86299.jpg https://cimg1.ibsrv.net/gimg/www.evo...f0d914bdc.jpeg Now here's the pinout for an Evo 8 WITH ACD. I can't tell you if it's the same for non ACD evos. Be wary. This is the evo harness with the two plugins connected to the evo cluster. C-106 (White Connector) 1 BLK...........Ground 3 2 BLK...........Ground 3 3 BLU/GRN.......Left Turn Signal (+) 4 RED/WHT.......High Beam (+) 5 BLK...........High Beam (-) 6 7 RED/BLK.......J/C 1 (+) (10AMP FUSED) 8 YEL...........Door (+) ---------------------------------------- Ignition 9 YEL/RED.......Charge (+) ---------------------------------------- 10 GRN/WHT......Tarmac (-) 11 GRN..........ECU/Tach Input 12 WHT/BLK......Speedometer Input 13 GRN/ORG......ABS 14 PNK..........Gravel (-) 15 VLT..........Snow (-) 16 17 WHT/BLU......Check Engine (-) 18 WHT..........Oil (-) 19 RED..........Charge (-) 20 BLU..........Fog (+) 21 C-108 (Blue Connector) 31 32 BRN..........Brake (-) 33 VLT..........Water Spray (-) 34 BLU..........Door (-) 35 RED..........Seat Belt (-) 36 GRN/YEL......Air Bag (-) 37 BLU/GRN......Brake (+) ---------------------------------------- Positive Lead 38 GRY..........General (+) ---------------------------------------- 39 ---------------------------------------- Negative Lead/Rheostat 40 BLK/YEL......J/C 3 (-) ---------------------------------------- 41 42 43 44 45 46 47 48 BLK..........(-) Fog (-) Turn Signal (-) 49 PNK..........Right Turn Signal (+) 50 YEL..........Water Temp Input 51 GRN..........Fuel Gauge Input Fog Light Switch 1 2 3 - Black Yellow - From Rheostat 4 - Green White + From fuse box 7.5a Hazard Warning Light Switch 1 2 3 - Green White + From fuse box 7.5a 4 - Black Yellow - From Rheostat Your next step is going to be figuring out that wiring. God be with you because it sucks if you don't know what you're doing lol. https://cimg2.ibsrv.net/gimg/www.evo...a8250cd299.jpg After going through that mini version of hell you should end up with a semi functional cluster. From what I can tell, RPMs and Fuel level read fairly accurate even without the Ktuned converter applied. Coolant will most likely read very low, or very high at first. No worries. And your speedometer most likely won't work at all unless you have the Ktuned converter applied. https://cimg8.ibsrv.net/gimg/www.evo...1b6d6ca51a.jpg After you've tested your connections and have everything that you want done, pop that sucka in there and see how she looks. You do not have to modify your cluster shroud at all, just push your wiring back in gently and place the cluster behind it. https://cimg0.ibsrv.net/gimg/www.evo...a2d49ed2db.jpg From here you can either make your own template for the cluster, or you can ask a company to cut one for you. (I'm through @JD_customs_usa as they'll be cutting me a carbon plate and shipping it to me. https://cimg2.ibsrv.net/gimg/www.evo...7142144952.jpg At the very end of all of this, you should end up with something like this. https://cimg6.ibsrv.net/gimg/www.evo...bfa4261252.jpg https://cimg7.ibsrv.net/gimg/www.evo...6c9c349d79.jpg Link to my Facebook startup video: https://m.facebook.com/story.php?sto...00004924896922 I'm nowhere near finished. Since I still plan on doing an LED swap for the cluster along with a different colored template. I'll update this accordingly as I keep going through this project. I'm going to go back and make a more direct pinout for the wiring soon. I'd like to make it as simple as possible for everyone. Thanks for the read, hope you guys enjoy it and appreciate the work and research that went into it. S2K Cluster harness S2K AP1 cluster Ktuned S2K cluster converter.<br/><br/>This allows you to adjust your speedo, coolant, and fuel level for accuracy. AP1 Pinout. Honestly you won't use much of this.<br/><br/>If the evo doesn't have it, just cap it or cut it off. AP1 pinout Evo cluster harness |
Man , that's is pretty dope man .. great write up . !
Originally Posted by coolie0707
(Post 11771200)
It got better feedback than I expected lol. |
That ended up coming out REALLY good.
looks good! needs an in-action video
Originally Posted by llDemonll
(Post 11771248)
Awesome! Thank you!
subd
This is great... but now you don't know when to shift at Tarmac or Snow RPM! :p
Wow, one hell of a job to tackle, props to you
Originally Posted by Ev0ikon
(Post 11771437)
I run a built t-case and have ACD deleted on my car, so there was no reason to incorporate the lights in haha. |
I'll be updating and adding more information to this as I finish this project up.
Waiting on my calibrater to come in, also sourcing a company that can reprogram the cluster to my original mileage. I'll add all of this to the thread once It's 100% Thanks for all the comments and kind words. |
Suuuupp.
Ktuned dash converter came in today. My car is currently in the shop right now having some stuff installed & being tuned. Hopefully I can jump back on the cluster later this weekend and start adjusting my speedo & coolant. https://cimg8.ibsrv.net/gimg/www.evo...b0b96b672b.jpgDash converter from K-tuned. ft. DxD tiddies. NFSWWWWWWW. |
Thanks for the write up! Is the evo 8 pinouts the same as the 9?
Originally Posted by e30_pilot
(Post 11772601)
It SHOULD be pretty similar if not exactly the same for a 9. But don't hold me to it. Do some digging and find out for us lol. Best of luck. 👍 |
