NEW HKS TURBO TIMERS! Now in stock!
HKS 35th Anniversary Turbo Timers
Type 1 155.00
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
* Positive Lit LCD
o Blue Back Light
* Black Display Case (W:89.5mm/H:22.5mm/D:13mm)
* LCD Display (W:41.5mm/H:11mm)
* Black Control Unit Case (W:69.0mm/H:80.0mm/D:21.0mm)
* Timer Functions:
o Manual Mode (0-10 Minutes)
o Memory Mode #1 (1 touch, 1 Minute Setting)
o Memory Mode #2 (1 touch, 3 Minute Setting)
o Auto Mode (0-5 Minute Setting)
* Battery Voltage Display:
o Battery Voltage
o Peak Value Indication
o ON/OFF Warning Function
* Vehicle Speed Indication Function:
o Vehicle Speed
o Peak Speed Hold Value
o Speed Warning Function
* Engine RPM Indication Function:
o Engine RPM
o Peak Engine RPM Hold Value
o Engine RPM Warning Function
* Display in either MPH/SAE or KPH/Metric
* Metric Distance Time Functions:
o Acceleration Distance (0-100m, 0-200m, 0-400m)
o Section Time (200-400m)
o Acceleration Time (0-100km/h, 100-150km/h)
o Auto or Manual Start for Quarter Mile Function
* SAE Distance Time Functions:
o Acceleration Distance (0-60 foot, 0-1/8 mile, 0-1/4 mile)
* Stopwatch Tool Time Measurement
o Total Elapsed Time
o Lap Times
* Compatible with all HKS Turbo Timer Harnesses
Type0 99.00
The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
* Positive Lit LCD
o Red Back Light
* Timer Functions:
o Battery Voltage
Harnesses are available for plug and play! For Mitsu applications!
