Import DPS Presents AEM Wideband+Autometer Pod+Boost Gauge Just $269 Shipped
Import DPS is having a REALLY good combo deal for Evolution 8 and 9 owners. This combo deal not only will add a special look to your interior, but it will also make watching your boost levels and air/fuel ratios a lot easier by using the Autometer Steering Column Pod.
Here is what you get....
*** AEM 30-4100 Wideband Uego Gauge Controller ***
MFG Info - A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
* Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
* Does not oscillate AFR reading like narrow band sensors
* No laptop required for monitoring!
* Bosch sensor included
* Accurate to 0.1 AFR
* Reads in AFR or Lambda via a switch in back of gauge housing
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
* Integrated three-digit display reveals AFR or Lambda in real time
* User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
* Serial data stream included for output of AFR (RS 232)
*** Marshall Electronics Pro Street II Boost/Vac Gauge ***
MFG Info - Item: 8011. Marshall Instruments PRO-Street 52mm performance gauges have ultra bright displays with LED backlighting. Aluminum anodized bezel and illuminated red pointer complete the sophisticated look.
Case Diameter: 2-1/16" (52mm)
Movement: 270 degree full-sweep
Tubing Kit Included: Yes
Gauge Type: VAC/BOOST
Gauge Range: 30" Hg - 30 PSI
Gauge Face Color: Black
Gauge Number Color: White
Lighting Type: Through Dial LED
Lighting Color: White and Amber
Lens: Tinted
Pointer Color: Red
Bezel Color: Silver
*** Autometer Dual Steering Column Pod ***
MFG Info - #20024 from Autometer. Mounts right over the factory location.
To order, just call us at 866-703-8794 and mention your from EvoM to receive the combo deal. These will sell out very fast. Actual picture of both gauges mounted tomorrow will be posted for everyone to see how hot this will look.
We accept Visa, Mastercard, American Express and Discover Cards. Cash Pickups also welcome but please add 7% Sales Tax.
Thanks EvoM
Import DPS
Lens: Tinted
Pointer Color: Red
Bezel Color: Silver
Thanks EvoM
Import DPS
