ACT Full Face Street Clutch Assembly 545.00 SHIPPED
Old Feb 21, 2007, 06:53 AM
Stripper's Avatar
Well, here's the deal. I think im the only Evo/DSM guy here at Stripper, so I'm gonna jump in here and try to give the hook ups. I'm going to do this kit for 545 shipped to your door if you're in the US. If you want a flywheel or anything else at all, we can workout a better deal probably. I carry everything and can usually beat anyone's price.
Call and ask for Brian. I don't think anyone else here would give this price like I am. Don't tell!
Toll free 866-708-7744
I'm here from 5-9 eastern time.
Thanks for the space!
-Brian
ACT Clutch Kit with ACT Heavy Duty Pressure Plate and ACT Performance Organic Street Disc. ACT Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life.
What makes ACT Pressure Plates the highest standard in the industry?
First, ACT manufacturing always begins with new units. ACT Pressure Plates are not rebuilt from worn out parts.
Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear.
Third, ACT designs the pressure and release travel of the unit to be in the optimum working range.
Finally, ACT assures consistency and precision by using proven assembly procedures. Every unit ACT produces is accurately balanced and tested.
ACT Street Discs are designed for smooth engagement, quiet operation and improved durability using only the best organic, spring center designs. When an Act Modified Street Disc is available, the suffix "MM" appears in the disc part number. The marcel of the disc has been modified to enable quicker action. When a special ACT Performance Organic Street Disc is available, the suffix "SS" will appear. These discs use special steel backed performance linings designed to withstand high heat and abuse. Most of these "SS" discs are also modified for quicker shifting. What is all the hype about different lining materials available? ACT still contends that nothing can beat a good quality organic disc for street use. Virtually all the premium sport car manufacturers use organic discs.
This kit includes these components:
MB017 - Heavy Duty Pressure Plate
MBSD088S - Performance Street Disc
RB601 - Release Bearing
AT03 - Alignment Tool
Torque Capacity: 497 ft/lbs.
Stripper is offline
Old Feb 27, 2007, 08:30 AM
Stripper's Avatar
bump it up
Stripper is offline
EvoX 'For Sale' Engine Internals and Drivetrain
135
Jun 14, 2016 10:31 AM
Kami Speed
Jul 2, 2009 12:54 PM
Oct 31, 2008 07:02 AM
STikiller.com
Evo 'For Sale' Engine Internals and Drivetrain
24
Aug 18, 2008 10:16 AM
14
Jul 22, 2008 05:12 PM
Quick Reply: ACT Full Face Street Clutch Assembly 545.00 SHIPPED
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
