Kartboy Short Shifters- SOME OF THE LAST LEFT IN THE COUNTRY!
So we were lucky enough to secure 3 of the last Kartboy Short Shifters available This is a sleek and sexy little black number that's just itchin' to get on your Evolution 8! These are meant for the 5-speed transmission and come struttin' in smellin' like 110% top quality that you expect from Kartboy!
NOTE: Since the stock lever is welded around the upper plastic pivot cup you have to break the plastic cap to remove the stock shifter. It is required you buy this part is required to install the shifter. The Mitsubishi genuine part number is MR246296.
Originally Posted by Kartboy USA
The Kartboy short throw shift lever for the Mitsubishi Lancer Evolution 8, it provides a reduced height and throw versus the stock lever. This CNC machined, 4130 Cr-Mo Steel lever, electroplated black, reduces shift throw by 25% and lowers the shift knob by 10mm. While not a dramatic change from the comparatively short, stock system, the lever provides a more sporting feel, without the need to grind out pieces of plastic in the mounting frame.
!!!COMPLETELY SOLD OUT!!!
