Cosworth EVO 8 & 9 engine parts
Old Aug 7, 2007 | 12:27 PM
RallySport Direct's Avatar
Silver Sponsor
We now have available to us EVO 8 & 9 engine components.
Short Blocks,
2.0 L 6,375.00
Each High Performance Short Block is hand assembled by one of Cosworth’s skilled engine builders to exact specifications. Built from all new components, the Cosworth 4G63 2.0L engine is the perfect foundation for your high performance application.
Each short block features:
* Cosworth Forged Pistons(85mm)
* Cosworth Forged H Beam Connecting Rods
* New Mitsubishi Forged Crankshaft (88mm)
* Cosworth High performance Rod and Main Bearings
* Cosworth High Performance Main Bearing studs
* New Mitsubishi 4G63 Block.
Each assembly is carefully blueprinted and balanced and includes a build sheet listing all critical dimensions.
2.2 L short Block. 9,200.00
The Cosworth 4G63 2.2L stroker engine combines the perfect bore to stroke ratio, yielding potentially big gains in torque while still allowing the engine to rotate and produce power higher rpm's. This is the perfect foundation for your big power engine build. Combine with one of our CNC ported Big Valve Cylinder Heads and Camshaft sets for maximum reliable power.
Each Cosworth 2.2L short block features:
* Cosworth Forged Pistons(86mm)
* Cosworth Billet Crankshaft (94mm)
Cosworth Evolution VIII 4G63 Replacement Ported Cylinder Head 3,849.00
real world power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for big turbo applications. A flow chart for the modified head is available by downloading the technical document on the left.
Specification
# CNC Ported/machine finished port - New OE Castings
# Hand blended finish work
# Intake – 26% Increased Flow (max)
# Exhaust – 18% Increased Flow (max)
# 4-angle Inlet Valve job
# 3-angle & radiused Exhaust Valve job
# Valves are lapped
# Back-Cut Inlet Valves
# Heads are Ultra Sonic cleaned prior to assembly
# Heads are Serialized and sport a machined Cosworth logo
# +1mm Stainless Steel Intake Valves (1800 degrees max.)
# +1mm Inconel Exhaust Valves (2400 degrees max.)
# Performance Valve Springs
# Titanium Retainers
# Hardened Steel Spring Platforms
# Reshaped combustion chamber
Cosworth Mitsubishi Evolution Camshafts 599.00
Cosworth camshafts are ground on NEW chill cast cores to the highest standards. Each cam profile is carefully designed to maximize performance across the entire power band, producing strong power gains throughout. Prices includes two camshafts
# Ground from NEW Chill cast billets
# Engineered and tested profiles
# Compatible with Cosworth CNC Ported Big Valve Cylinder Head
We also stock Cosworth Pistons, Bearings, Rods, Head gaskets, and all the other Cosworth engine parts!
Old Aug 7, 2007 | 12:30 PM
High_PSI's Avatar
Oh man, what kinda power is this stuff rated too? I like that 2.2 block.
Old Aug 7, 2007 | 12:52 PM
Silver Sponsor
Knowing Cosworth, these parts will handle everything you can throw at it
Old Aug 10, 2007 | 11:21 PM
*WRC*'s Avatar
how much to ship to Australia, Queensland 4076, 2.2 block & head.
Old Aug 13, 2007 | 11:03 AM
Silver Sponsor
You got a PM
Old Oct 4, 2007 | 10:12 AM
Silver Sponsor
Heads and Cams in STOCK!
Old Nov 7, 2007 | 11:55 PM
red evo8's Avatar
pm price of cossi 9 cams to 76180
Old Nov 8, 2007 | 08:26 AM
Silver Sponsor
PM sent
Old Nov 27, 2007 | 05:26 PM
Silver Sponsor
Bump!
Old Dec 1, 2007 | 05:46 PM
SWOLN's Avatar
Bump, cause I got a hard on for the 2.2 set-up. ...Except, why no IX head price?
Old Dec 3, 2007 | 08:59 AM
Silver Sponsor
The EVO IX heads just barely came out.
The price is 4200.00
Old Dec 13, 2007 | 04:45 PM
Silver Sponsor
Cams in stock!
Old Jan 11, 2008 | 10:07 AM
Silver Sponsor
To the top!
Old Apr 2, 2008 | 09:14 PM
red evo8's Avatar
pm price of cossi evo 9 272's m2's
Old Apr 3, 2008 | 05:24 AM
Randy's Avatar
Send me a PM is Cosworth has a replacement headgasket with stock specs.
Thanks
