Forced Performance EVO8 Cam BLOWOUT!
Hello. Forced Performance isn't new, but we are new to vendorhood on EvoM. To celebrate our new vendorhood (did I just create that word?) we are going to blow the F out of some EVO8 camshafts. Cut me a little slack if this post is out of whack, like I said I am new to "vendoring"
Ok, so we have an overstock situation on our 100, 200 and 300 grind EVO8 camshafts, so we are offering a terrible ugly low cost on them for a limited time.
***edit o add price $299 per set*** NOW JUST $250 per set
Specific info for the cams such as camcards, lobe graphs, comparison to stock lobe etc can be found on our website here:
http://store.forcedperformance.net/m...=Lancer-Engine
the basic specs are as follows:
100 aka 264plus
Intake - .434 valve lift, 202 dur @ .050"
200 aka 270plus
Intake - .434 valve lift, 210 dur @ .050"
300 aka 280plus
Intake - .434 valve lift, 218 dur @ .050"
100 aka 264plus
Exh - .411 valve lift, 202 dur @ .050"
200 aka 270plus
Exh - .411 valve lift, 210 dur @ .050"
300 aka 280plus
Exh - .411 valve lift, 218 dur @ .050"
So these fit into the typical "264, 272, and 280" slots with a little more lift on the smaller grinds than you would see in the HKS version. Great lobe location on all three grinds also, easy to get great power out of them without a bunch of cam gear dyno testing - install straight up out of the box. Again these are 4G63 specific lobes, not small block chevy lobes ground onto DSM blanks by some guy that cut his teeth on carbs and V-8's that thought it would be neat to make some import cams.
To even make this deal better you can add a set of our BRAND NEW beehive springs that drop in stock heads and retain the factory MMC retainer for the lightest weight spring and retainer set possible FOR ONLY AN EXTRA $100.
I know this is getting long, but bear with me.
You can get the camset of your choice, or mix and match intake and exhaust (200 intake and 300 exh for example) AND get the best evo valve springs on the market for only $399.
We have all this in stock, ready to ship, no delays, no waiting on a GB order to arrive, no nothing but you getting your parts FAST and CHEAP. If you want to get happier than this you will need a girl.
BOOST ON!
Robert Young
100 aka 264plus
200 aka 270plus
300 aka 280plus
100 aka 264plus
200 aka 270plus
300 aka 280plus
BOOST ON!
Robert Young
Last edited by ForcedPerformance; Sep 10, 2008 at 12:02 PM. Reason: forgot to indicate price :)
Which is the best cams that will make more hp/ faster in 1/4mile? I have BR HTA35R.
Can you chime in here too>>> https://www.evolutionm.net/forums/sh...d.php?t=334237
