ACT Clutch Kits 6 Puck Flywheel Combos EVO 8 Clutch line 800 shipped
ACT Clutch EVO 8 Clutch kit , Clutch line and flywheel Combo
ACT MB7-HDG6 Heavy Duty 6 Puck sprung Hub.
After spending long hours and thousands of dollars building that high powered engine, you need a quality clutch that can properly transfer that power into motion. Count on ACT clutches for quality, performance and affordability.
ACT recognizes that every driver and engine set-up is unique, so a variety of complete clutch kits and components are offered to match virtually any situation. ACT’s complete clutch kits include a pressure plate, disc, release bearing, and (in most cases) a pilot bearing and alignment tool. The kit guide on the next page will help you select the ACT kit that best fits your needs. The following pages include ACT clutch kits and components listed by application. Torque capacities are provided for every clutch combination. When a specific flywheel is required for an ACT Clutch, it will be designated in the chart for your convenience.
Consider carefully which clutch is right for your car. First you need a clutch that will hold all the power, but not too excessive. For street use, you also need a long lasting clutch that has a positive feel, smooth engagement and quiet operation. For racing, you need a tough clutch that will enable quick shifts and hard slips all the way to the finish line.
Torque Capacity 651 ft/lbs
Clamp Load Increase 36%
Pressure Plate MB017
SFI Yes
Disc: 6240608
SFI Yes
Release Bearing RB601
Pilot Bearing N/A
Align Tool AT03
Fidanza Lightweight Flywheel 161921
Fidanza aluminum flywheels are made from the highest quality 6061 T6 aluminum. This material is fantastic for strength, heat dissipation, and weight reduction. The friction surface is an incredibly strong 1045 steel. The friction plates are milled to meet high specifications.
A Fidanza aluminum flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the replaceable friction surface with military grade aerospace fasteners. With these replaceable friction plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it's life, saving time and money. The ring gears are also made from 1050 steel and are heat treated for durability. The flywheel ring gears are heated then pressed on and secured with grade 8 button screws. Fidanza was the first to utilize a stepped dowel system in most of their flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place.
Weighs 9.5 Pounds
800 Shipped to the Continental USA.
