!!! KELFORD /// HKS /// COSWORTH /// And many more!!!
At Big Valley Performance we offer the top products from many brands! Here is just but the tip of the iceberg from what we offer! PM for pricing and details!
Kelford camshafts, #1 in AMS shootout! ON SALE!!! http://www.bigvalleyperformance.com/...ord__53716.jpg http://www.hksusa.com/images/logo_hks.gif performance upgrades! Camshafts http://www.hksusa.com/images_products/L_1252.jpg Metal Head Gaskets http://www.hksusa.com/images_products/L_1256.jpg http://www.theboombopshop.com/v/vspf...s/Cosworth.jpg performance upgrades! Mitsubishi 4G63 (EVOVII-VII) Camshaft Set M1 Mitsubishi 4G63 (EVOVII-VII) Camshaft Set M2 Mitsubishi 4G63 (EVO IX) Camshaft Set http://www.amber-performance.co.uk/s...ils/KK3805.jpg Mitsubishi 4G63 (EVOVII-VIII) Forged Piston Set http://www.amber-performance.co.uk/s...%20Pistons.jpg ...And much much more! Product lines carried include Ferrea, ARP, WISECO, CP, INJEN, TurboXS and many others!!! PM for pricing and details! ACT CLUTCHES The model shown has a torque capacity of 651 FT/.LBS, a clamp load increase of 41%! Increased torque capacity and spline life, very good durability, quiet operation, and reduced driveline shock. Used by many daily driven and tracked Mitsubshi Evolutions, this is a great priced clutch for enthusiast on a budget! PM for pricing! http://www2.advancedclutch.com/image...clutch_kit.gifMB7-HDR4 http://www2.advancedclutch.com/prod_images/pp_HD_lg.jpg http://www2.advancedclutch.com/prod_...disc_R4_lg.jpg ACT FLYWHEELS "Most stock flywheels are heavy cast iron and are designed for optimum drivability by storing some of the engine’s power in the form of inertia. Light flywheels provide significantly improved engine response and acceleration by compromising drivability. Xact flywheels are designed for improving engine response, strength and affordability." PM for pricing! Streetlite / 13.1 lbs. - Preferred for Street and Drag Racing - Improved throttle response and acceleration - Considerably lighter than stock - Most durable flywheel available - Good drivability http://www2.advancedclutch.com/prod_...eetlite_lg.jpg Prolite / 10.1 lbs. - Preferred for Road Racing or minimum inertia - Quick throttle response and acceleration - Lightest with lowest inertia - Reduced drivability http://www2.advancedclutch.com/prod_...prolite_lg.jpg EXEDY Multiplate Clutch Kit "For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application." PM for pricing! http://www.bigvalleyperformance.com/...052__51785.gif Specs Number of Discs ~ Twin Spring Damper Discs ~ Sprung Hub Push / Pull ~ Pull Type Disc Outer Diameter ~ 200mm (7-7/8in) Spline Teeth / Major Diameter ~ 23T / 26.2mm Exedy Carbon Clutch Kit "The flagship model of EXEDY Racing Clutches: the carbon steel multi plate clutches. These clutches are light in weight, durable, and resilient to high heat, contributing to an improvement in track times. These complete bolt on designs require no additional modifications to the vehicle. The carbon materials are baked at more than 2000 degrees celsius which allows the the carbon material to dissipate heat far better than conventional metallic material." PM for pricing! http://www.ninjapower.co.uk/images/p...ZM023SBMC1.jpg Specs Number of Discs ~ Triple Spring Damper Discs ~ Solid Hub Push / Pull ~ Pull Type Disc Outer Diameter ~ 200mm (7-7/8in) Spline Teeth / Major Diameter ~ 23T / 26.2mm TILTON EVO OE Diameter clutches "Tilton Performance offers three clutch packages for the Mitsubishi EVO VII (non-MR). The three clutch types have been developed to meet the requirements for high-performance street/strip and racing applications. Clutch options include a Cerametallic/Organic Hybrid, Cerametallic and Carbon clutch. The flywheel included in the packages has been engineered to have a compromised weight/inertia that provided increased performance (faster engine acceleration) and good drivability (reduced bogging). Also included with each clutch package is a hydraulic release bearing (HRB) that mounts inside the bellhousing and replaces the stock slave cylinder/fork arm release bearing mechanism. The HRB provides quick shifting, low pedal effort and self-adjusts for clutch wear." PM for pricing! # 7.25" 2-pl Carbon CFAs # 7.25" 2-pl Cera/Organic CFAs # 7.25" 2-pl Cerametallic CFAs http://www.tiltonracing.com/incs/pro...hp?sid=343&m=d Ok guys we are runing a SALE on WISECO PISTONS+EAGLE RODS ALL IN STOCK http://www.bigvalleyperformance.com/...776__80617.jpg http://www.bigvalleyperformance.com/..._01__08746.jpg PM FOR THE COMBO PRICE!! Other makes and model available as well...PM for details! |
pm price for Evo 8 Kelford TX272s shipped to 11223
^replied
All PM's replied! ttt
pm price for Evo 8 Kelford TX272s shipped to 07071
bump runnin fully built cosworth head...cams are soo meann
ttt!
Monday bump!
ttt
bump
Trick or Treat! Bump!
ttt!
Bump!
Friday bump!
Bump! =)
