ATS Carbon Twin/Triple Plates, Exedy/Cusco Twin Plate Clutch Kits - FREE SHIPPING!
Carbonetics ATS-ACROSS Triple and Twin Plates Carbon Clutch Kits
The Carbonetic Triple Clutch is designed for extreme power as high as 1500ps (1480hp). Its half clutch operation is the ultimate in control, surpassing that of a single or twin clutch. The inertia weight is kept to a minimum, thus enabling quick shifting.
By instilling our clutch with triple plates constucted of the non-mesh random waving method, the Carbonetic triple clutch is astonishngly strong and built to repeatedly handle the severest driving conditions.
Triple Carbon Plate 1350kg pressure plate good for up to 1500 hp & 1500 lb/ft tourqe.
*Chromoly Lighten Flywheel is included.
List Price: $2800, Buy Now for Only: $2379 Free Shipping!!
The Twin-Plate Carbon Clutches are the intermediate selection that will handle between 500PS to about 900PS at the crank. Much smoother operation while driving on slopes or in traffic than the metal multiplate clutches.
List Price: $2260, Buy Now For Only: $1949Free Shipping!!
For both competition and road with excellent maneuver Easy to slip in, diaphram designed for smooth and light use. A light clutch that enables good clutch maneuvers. HEAT RESISTANT Improved higher ? low friction and high heat resistant. Carbon rich facing used on the disc with ventilated type center blade. DURABILITY Self leveling offers longer clutch life. The self leveling system balances equal wear on both the flywheel and transmission side of the disc to promote longer clutch life. FITTING A pull type bolt on type makes easy mount. The pull type does not require adjuster kits and the bolt on allows easy fit. * Includes pressure plate, twin clutch packs, chro-moly steel flywheel.
MSRP: $1760, Buy Now for Only: $1499 Free Shipping!!!
EXEDY Regular or Heavy Duty Twin Plate Clutch Kits
For high-powered applications, EXEDY offers twin and triple Multi-Plate Clutches. These are designed for hot street action as well as drag, road and rally racing. The twin plate clutches are rated for above 500hp to 750hp. The triple plate clutches are rated for up to and over 1000hp (for drag race applications). Twins come as with both spring damper discs and solid discs. Triples are all solid discs. All Exedy multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover. Depending on the application, we have both strap drive and lug drive models. All have T5001 cerametallic friction materials for extreme heat resistance. Engine modifications e.g.. cam-timing-turbo modifications etc. cause engine pulsation and vibrations. These vibrations can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. These noises will in no way affect the performance of the Exedy Multi Plate Clutch. This rattle is well accepted in the performance industry where engine modifications have been carried out. Rated WHP: up to 500whp * Includes pressure plate, twin clutch packs, chro-moly steel flywheel.
Regular Twin Plate - MSRP $2392, PM for Best Pricing!
Heavy Duty Twin Plate - MSRP $2484, PM for Best Pricing!
FREE Throw Out Bearing w/ Purchase of any Exedy Twin Plate Clutch Kit
Thank you
Calvin
Thank you
Calvin
Perrin Performance Products
Perrin Intake System
Increase horsepower and style under the hood of your Evolution! Our designers have released a system for the EVO that is not only value priced, but looks great and prevents any issues associated with nasty Check Engine Lights. You will see consistent gains in horsepower, throttle repsonse and fuel economy. Our kit includes a power-coated cold rolled steel heat shield to prevent heat soak and a high-flow foam filter. Fits all models 2003-06.
MSRP: $159.99, Our price: $143.99 Free Shipping!
Perrin Panel Filter
Don’t let a flimsy paper filter get between you and true performance. The PERRIN Performance™ dual stage, “Open Cell” foam, drop-in Panel Filter is the answer. A stealthy approach to higher air flow. Increases in horsepower are a simple easy install away! Quick cleans are simple with our aerosol cleaner and spray oil.
MSRP: $64.99, Our Price: $54.99 Free Shipping!
Perrin Intercooler / Boost tube kit
Turbulent free airflow is the key to added performance and horsepower. The PERRIN Performance™ Boost Tube extends from the throttle body to the cold side hard pipe and increases internal diameter by more than 15% over stock! Also includes two additional couplers to color match to the front mount intercooler for a show quality look.
MSRP: $279.99, Our Price: $250.99 Free Shipping!!
Perrin Turbo Induction Upgrade Hose
Simple to install and easy to appreciate, the PERRIN Performance™ Inlet Hose is an eloquent compliment to every engine bay. Replaces the factory corrugated rubber hose between the MAF sensor and turbo. Removes turbulence, increases flow rates, improves horsepower, torque and throttle response! Works with the factory air box, the PERRIN Intake and many of our competitors systems as well. Economically priced and available in red, blue or black.
MSRP: $249.99, Our Price: $224.99 Free Shipping!!!
Perrin PWI-1 Water Injection System
The process of compressing air to create boost and power, has a nasty byproduct of heat. Heated air lacks the density to make higher horsepower, increases detonation and forces the ECU to pull timing. All of which reduce the power you are looking to create. In order to combat this heat, we manufacture air-to-air intercooler upgrades for nearly every vehicle we offer products for. But we are always restricted by the physical restraints of the vehicles size and by the fuel offered at the pump. Yet, high horsepower engines demand additional cooling and detonation control. This is where Water/methonol injection come into play.
Included Items:
*PWI-1 Pump Assembly
*PWI-1 Brain Box
*PWI-1 Dash Display
*Main Wire Harness
*Brain Box Wire Harness
*Ring Terminals
*Float Switch
*4mm Hose
*6mm Hose
*Pre-Pump Filter
*Nozzles 1.0mm, .8mm, and .6mm sizes
*1/8NPT Nozzle Seat, and plug
*1/8NPT Tank Bung
*90 degree push-lock connector
MSRP: $749.99, Our Price: $674.99 Free Shipping!!!
Perrin Panel Filter
Included Items:
*PWI-1 Brain Box
*PWI-1 Dash Display
*Main Wire Harness
*Ring Terminals
*Float Switch
*4mm Hose
*6mm Hose
*Pre-Pump Filter
*1/8NPT Tank Bung
BuddyClub Pro Spec Exhaust - 03+ EVO VIII & IX
Buddy Club Pro Spec is a super light weight and highly efficient muffler that is made to perform for circuit runs. In its street version, to optimize torque in the low to mid speed range, it is equipped with an efficient middle silencer (resonator). Pro Spec Mufflers were designed for high performance as well as meeting sound level standards. With its deep throaty tone, it echoes its racing lineage. The middles silencer achieves both exhaust efficiency and sound dampening requirements. Usual mufflers are designed to "muffle" sound and results in restricting performance. Our mufflers, with results of trial and error, have developed the highest possible performance while maintaining a low throaty tone. We only used the finest material, that meets high endurance, light weight, and excellent fit. The inner silencer is included with all mufflers. When installed it meets volume safety standards. Improvement in durability can be seen by the use of "band- stay" hooks as attachment to the main silencer.The absence of welds help maintain the light weight frame. In continuing the light weight form the muffler tip is made with a slight incline cut.This is a demonstration of commitment to performance and style. A mark of quality and craftsmanship, all muffler are engraved with the Buddy Club insignia.
MSRP: $599, Our Price $499 Free Shipping!!!
Perrin Evo Catback Exhaust: 03+ EVO
The PERRIN Performance Evolution Exhaust is constructed of full 3 inch stainless steel tubing. Fully flanged complete cat-back unit, which does not affect emissions related hardware. Every PERRIN straight-though exhaust design allows for peak performance and horsepower. A large 4 inch, slash cut, stainless steel tip sets this system apart. Full 3 Inch System High polish canister and tip Fully Flanged System Single 4 Inch Slash Cut Tip.
MSRP: $649.99, Our Price: $584.99 Free Shipping!!
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
19
Aug 1, 2010 11:23 AM
Gruppe-S
Sep 19, 2005 08:27 AM
500whp.com
37
Sep 5, 2005 02:59 PM
Gruppe-S
50
Aug 22, 2005 02:49 PM
Gruppe-S
20
Mar 21, 2005 10:42 PM
