Cobb Access Ports, Cpbb Stage1. and Cobb Stage2. In stock Ready to ship! 24% more HP!
WE ARE COBB TUNINGS LARGEST RETAILERS! AND WE ARE HAPPY TO OFFER YOU THE BEST DEALS ON THE INTERNET ON COBB ITEMS!
NO ONE SELLS MORE COBB THEN WE DO! NOT EVEN COBB THEMSELVES!
The AccessPORT is a handheld device that allows you to reprogram your vehicle's computer (ECU) to optimize parameters such as the air/fuel ratio and ignition timing. The "mapping" will also increase boost, remove the speed limiter, and more for instant performance results you can feel!
Evolution AccessPORT features are as follows:
» Improve horsepower, torque, and fuel economy at the touch of a button
» Display vehicle data such as RPM, temperatures and more while you drive
» Easy installation, no mechanical or computer skills necessary
» Connects to your vehicle via the OBD-II port conveniently located under your dash
» Exclusive ability to switch between different 'modes' on the fly
» Pre-calibrated to maximize performance of stock or modified vehicles
» Easy-to-read color display
» Update over the Internet to stay up-to-date with the latest features
» Read engine trouble codes (DTC) yourself, eliminating trips to the dealership
» Not a "piggyback" - once vehicle's computer has been programmed by the AccessPORT, it can be removed and the settings will stay on your computer.
» Not just an "ECU reflash" - AccessPORT features enhancements such as on-the-fly mode switching, data monitors, reading DTCs, performance monitors and more
» Can be custom tailored to your vehicle by our extensive network of professional tuners
The EVO VIII can see gains of +24% hp and +20% lb-ft.
The EVO IX can see gains of +24% hp and +10% lb-ft.
The Cobb Tuning Evolution Accessport for the 8 and 9, will work on all USDM versions.
ACCESS PORTS are 695.00 SHIPPED, and IN STOCK!
CAT BACK
The COBB Tuning catback exhaust have been heralded often for the quality, performance, and subtlety. We continue this tradition with our new Mitsubishi Evolution exhausts. Engineered to be a vehicle specific unit, the catback exhaust uses the highest quality 304 stainless steel mandrel bent piping and a muffler designed for direct and efficient flow of exhaust to achieve the highest performance while still retaining a stock like appearance and low sound level.
Fitments available for the JDM or USDM bumper.
Approximately 6 lbs. Lighter then OEM Piece.
Sound Measurement Data:
Stock DP & Cat with Cobb cat-back - idle - 80db SAE J1169 - 88db
LINK TO THE VIDEO OF THE CAT BACK!
PRICE 625.00 SHIPPED! IN STOCK READY TO SHIP OUT!
DOWN PIPE
A turbo downpipe is one of the premier modifications most EVO owners look to upgrade on their vehicle. We engineered our downpipe to fit the specific needs of the EVO chassis. The COBB EVO downpipe fits within the factory chassis bracing without the need for additional spacing. Made of 304 stainless steel mandrel bent tubing, this downpipe can be fitted with the OEM cat back exhaust or our COBB Tuning Test Pipe and performance Cat Back system.
NO SPACERS REQUIRED! BEST DOWN PIPE THAT WE HAVE EVER INSTALLED!
PRICE 275.00 SHIPPED! NOW IN STOCK!
INTAKE
The COBB Tuning SF Intake utilizes our custom design to maintain optimal flow and net the ideal performance. The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. The COBB Tuning SF Intake system is compatible with Stage 1 and Stage 2 OTS (off the shelf mapping) provided for our AccessPORT ecu tuning device.
PRICE 115.00 PLUS SHIPPING! NOW IN STOCK!
HEAT SHIELD
The Cobb Tuning Heatshield for the 2003-06 Evolution, redirects the hot air coming off of the exhaust manifold away from the intake. This allows the intake to draw in more cool air, resulting in more power.
PRICE 135.00 PLUS SHIPPING! NOW IN STOCK
STAGE1
Access Port
CatBack
Intake
PRICE 1435.00 SHIPPED! ALL ITEMS IN STOCK!
CAT BACK
DOWN PIPE
INTAKE
HEAT SHIELD
STAGE1
Access Port
CatBack
Intake
