MIL.SPEC HIGH Pressure Throttle Shaft Seals/100 Cell Cats are available
For $275 you send us your throttle body and we send you back:
A ported 65mm TB that won't sound like a trumpet section, is completely rebuilt, comes with our very own MIL.SPEC high pressure throttle shaft seals tested to 35psi, has a TPS sensor calibrated to OEM specs, incorporates a machined throttle shaft for improved flow and is paired with an OEM gasket machined to match our 65mm TB. That, my friend, IMHO is a pretty darn good deal. And our throttle bodies are the only ones that combine all of those features into one unit.
If you want to pay less than $275, you'll be getting less. And, in some cases, you'll be getting less even if you pay more.
AMS, along with our other shops, seems to think they're pretty good too
