M4: AMS Evo 8/9
M4: AMS Evo 8/9
Now at Method 4 Motorsports: AMS Wet Sump Oil Pan!
The AMS EVO VII/VIII/IX Wet Sump Oil Pan is designed to keep oil where it needs to be even in the most severe racing scenarios. The stock oil pan for the EVO did not take into account the effects that sustained high speed turns or acceleration can have on the oil. During these situations oil can be pushed to one side of the pan causing vital engine components to be starved of oil. The AMS Wet Sump Oil Pan will not only accommodate another 1.5 quarts of oil but by using a trap and kick outs, it enables oil to stay where it is needed. The added capacity and aluminum construction have the added benefit of keeping the oil cooler. The AMS wet sump pan is a must for every type of racing.
Features
• 100% 6061 aluminum construction. Hand TIG welded
• Additional 1.5 quart oil capacity over stock
• Front kick out area to allow for more oil capacity
• Integrated Trap door preventing oil from shifting during lateral acceleration
• 3/4” deeper than stock pan
• Custom oil pickup
• Integrated crank oil stripper
• Complete bolt on with no other modifications needed
• Bolts right up the factory or aftermarket oil return lines
• Adds more clearance for factory and aftermarket downpipes
• Unrivaled fit and finish
Specifications
• 6061 hand TIG welded aluminum construction
• 6.5 quart oil capacity
• 3/16” thick aluminum construction
Applications
• Mitsubishi Evolution VII, VIII And IX Models
• Fits all USDM, JDM and European Models
Some clearancing may be necessary due to the difference in stroke and rod sizes in various EVO engine combinations.
Made in the USA by Moroso for AMS.
PM for unbeatable M4 EvoM pricing!
Features
• Custom oil pickup
Specifications
Applications
Andrew@AMS
Automotosports - Illinois
26
Jul 7, 2019 06:20 AM
FS[West]: AMS Wet Sump Oil Pan
gptoyz
Aug 27, 2015 06:46 PM
mchristian
Nov 8, 2014 08:29 PM
Touge Factory
Nov 20, 2009 04:58 PM
