Synapse DV Series Diverter Valve Kit - EVO 8/9/X / Ralliart 2.0T
The new Synchronic Diverter Valve is the first compact DV/BOV that uses the patented Synchronic actuation technology, eliminating the need for diaphragms by using a piston actuator that does not require frequent lubrication.
This Diverter Valve has been designed to hold 60psi of boost but is still fat acting enough to eliminate compressor surge.
The DV series valves can be used as either a pull-type or push type DV/BOV and will work directly with all standard BOV adapters, allowing for easy installation.
Features:
- Compact diverter/blow off valve
- No diaphragm
- Interchangeable with all adapter flanges
- Install as Pull or Push type valve
- Pressure tested to hold 60psi of boost
- Incredibly fast actuation
Fits: EVO 8/9/X
Please contact us for intro pricing or if you would like to put one on order!!
Price shipped to Romania/060875; USPS Express if possible.
The SSQV adapter kit.
Thanks.
Thanks.
