-   Evo 'For Sale' External Engine / Power (https://www.evolutionm.net/forums/evo-sale-external-engine-power-116/)
-   -   HKS DLI2's $465 shipped (https://www.evolutionm.net/forums/evo-sale-external-engine-power/212609-hks-dli2s-465-shipped.html)
Chris@nolimitmotors Jul 20, 2006 08:42 AM
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture.
http://i6.photobucket.com/albums/y22...097/L_2617.jpg
Call toll free at 1-866-381-4618 and ask for CHRIS to order. $465 shipped
