Ralliart Engine Accessories - You won't find these ANYWHERE else!!
Just got in the new shipment of Ralliart engine components. Stock is limited so please place your orders before we run out!!
Ralliart Super Sports Air Filter - Genuine JDM Ralliart Super Sports Air Filter - Multilayer design for optimal filtering & cleaning - Direct drop in replacement in stock air box $139 Shipped!! http://www.gruppe-s.com/Evo/evoeng/ralliartfilter.jpg Ralliart Sports Air Filter - Genuine JDM Ralliart Sports Air Filter - Dry paper filter element for best power/filtration ratio - Direct drop in replacement in stock air box $90 Shipped!! http://www.gruppe-s.com/Evo/evoeng/rartfilter.jpg Ralliart Engine and Tranny Mounts - Genuine JDM Ralliart Group-N mounts - Stiffer rubber compound to reduce drivetrain movement - Energy is focused to the wheels rather than shifting the engine - Complete set of front, rear, and side mounts. $189 Shipped!! http://www.gruppe-s.com/Evo/evoeng/Ralliart_mounts.jpg Ralliart Radiator Shroud - Red & Silver - Genuine JDM Ralliart Radiator Shroud - Lightweight anodized aluminum contruction - Channels air through radiator/intercooler for improved cooling - Available for both Evo 8 and Evo 9 applications $135 Shipped!! http://www.gruppe-s.com/Evo/evoeng/rart_shroud.jpg Ralliart Sports Spark Plug Cable Kit - Genuine JDM Sports Spark Plug Cable Kit - Reduced resistance for increased spark energy - Direct replacement for stock plug cables $105 Shipped!! http://www.poweraxel.com/ralliart/ca...image/s3-8.jpg Ralliart Thermostat - Genuine JDM Thermostat - Opens at 71 deg. C for better cooling during high load conditions - Bolts directly in place of your stock thermostat $89 Shipped!! http://www.poweraxel.com/ralliart/ca...image/s3-6.jpg Ralliart Underhood Fin Panel - Genuine JDM Underhood Fin Panel - Get rid of the boring black panel $179 Shipped!! http://www.gruppe-s.com/Evo/evoext/rart_hvent.jpg http://ads.boostlabs.com/banners/gruppes468x60_2.gif |
any red oil caps in yet? :(
Sorry, only radiator caps in stock. Oil caps are special order only.
Regards, Gruppe-S |
bump!
any ralliart push start button?
Regards, Mark |
Any CF lips for the IX? Thanks!
Originally Posted by Gruppe-S
They are readily available in Japan, but the price...$250 shipped!!
Regards, Mark |
hooptee - Sold out... it'll be ~1 month for the next batch.
MYEVOVIII - http://www.mitsubishi-motors.co.jp/e...pt01_im_08.jpg Thanks Max |
Curious about the Ralliart Super Sports filter... I know it's a dry-media panel, but can it be cleaned/reusued? If so, what is the procedure?
Originally Posted by amstel78
(Post 4127724)
it can be cleaned via the method as most filters...similar to the k&n, eventually you will have to replace it. hope that clarifies things a little bit. |
| All times are GMT -7. The time now is 04:28 AM. |
