Cobb Tuning Evolution 8-9 SF Intake! 115.00
http://www.rallysportdirect.com/shop...obb/751100.jpg
The COBB Tuning SF Intake utilizes Cobb's custom design to maintain optimal flow and net the ideal performance. The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. The COBB Tuning SF Intake system is compatible with Stage 1 and Stage 2 OTS (off the shelf mapping) provided for our AccessPORT ecu tuning device. In order to provide a system that looks as good on the outside as the technical advancements happening on the inside, Cobb utilizes a one piece design constructed from a high temperature plastic composite. Not only does this save weight compared to the previous metal design, the plastic composite material offers much better heat rejection properties that help keep intake air temperatures cooler. In contrast, intake systems constructed using metal castings or piping can actually retain underhood heat and in turn heat the incoming air. Price is 115.00 plus shipping! LINK TO THE ITEM! LINK |
Is it possible to get just the adapter piece...if it is how big is the opening in mm?
That is something that you have to get as a kit. Cobb will not sell it on its own.
Thanks Kirill |
bump!
