TTP E85 conversion kits available! FullBlown Twin pumps, walbro's, Ethamax injectors!
http://i4.photobucket.com/albums/y11...ttp_header.jpg
Part #1- E85 TTP EthaMax Injectors [TTP_e85_inj] $385 http://ttp-engineering.com/catalog/i..._injectors.jpg E85 Compatible TTP EthaMax Injectors Brand new set of (4) TTP-Engineering E85 injectors. Each set is flow matched to within 1-2% 1 year comprehensive warranty flow reports included with your specific flow results drop-in fitment for easy installation Price listed is for a matched/balanced set of 4 injectors PLEASE SELECT CORRECT SIZE FROM THE BELOW LIST: STANDARD SIZING 1150cc 1250cc Compatible with Gasoline and Ethanol up to 100% 1350cc Compatible with Gasoline and Ethanol up to 100% 1450cc Compatible with Gasoline and Ethanol up to 100% 1550cc Compatible with Gasoline and Ethanol up to 100% 1650cc Compatible with Gasoline and Ethanol up to 100% 1750cc Compatible with Gasoline and Ethanol up to 100% 1850cc Compatible with Gasoline and Ethanol up to 100% 2250cc available upon special request! All injectors feature the following... :mitsu:100% new manufactured injector :mitsu: Flow rates and set balancing completed pre-shipment :mitsu: Flow balanced to within 1-2% (flow report included) :mitsu: 100% drop-in fitment (no connectors or adaptors required) :mitsu: Excellent spray pattern and atomization for excellent idle and tuning :mitsu: Coil latency available upon request :mitsu: 12-month comprehensive warranty Best Pricing guaranteed! Click Here for PRICE QUOTE! CLICK HERE to Instant Message us! Click here to send us an EMAIL! __________________________________ PART #2 - FullBlown Twin walbro high pressure fuel pump housing: http://i4.photobucket.com/albums/y11...n_withpump.jpg Full Blown Twin Walbro pump Kit for use with stock lines or AN fittings! We have a dual pump hanger for the Mitsubishi Evolution that will allow you to drop 2 walbro fuel pumps into the stock gas tank. The days of drilling the stock gas tank and running loud external pumps are over. This is a must for those who are looking to make 500-1000hp. This kit comes complete with everything that you need to run a dual pump setup (besides the lines and hose ends). We have all the lines and fittings available as well. We currently run this twin pump setup on our own 600whp stock block E85 car. Best Pricing guaranteed! Click Here for PRICE QUOTE! CLICK HERE to Instant Message us! Click here to send us an EMAIL! http://www.nolimitmotorsport.com/2/walbro-fuelpump.jpg _______________________________________ Part #3- Additional Walbro fuel pump for boost activated 2nd pump The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour. Walbro in-tank electric fuel pumps utilize a proven gerotor design. The outside dimensions, however, are compact enough to fit existing hanger assemblies, without modification. Coverage includes most popular Acura and Honda, Ford, Chrysler and many other Import applications. Send us a message for PACKAGE PRICING! Best Pricing guaranteed! Click Here for PRICE QUOTE! CLICK HERE to Instant Message us! Click here to send us an EMAIL! |
These are the highest quality kits available!
Interesting...$385 for any of those non 2250cc injectors? Or am I mistaken?
Originally Posted by inco9nito99
(Post 7354307)
We have got a lot of responses on these kits. The hobbs switch for the 2nd pump which is boost activated is available from your local NAPA store.
how much for the 1650 shipped to 11210
PM sent
Many of the injectors can be found on our site at www.ttp-engineering.com/catalog |
All Ethamax injectors up to 1250cc are $385!
Originally Posted by TTP Engineering
(Post 7336934)
Ethanol content analyzer available in a combo price with the ethanol fuel system!
We can do combination deals on the Ethanol conversion packages to save you some money!
http://i4.photobucket.com/albums/y11...ttp_header.jpg |
ASK us about the combination pricing of all three components together!
(Post 7364147)
Is it safe for me to run the 1150cc injectors with a FP Red on E85? Also, can you PM me a price quote for all of the necessary components I'd need in order to run this? Thanks.
| All times are GMT -7. The time now is 08:40 AM. |
