Extreme PSI - Now offering the NEW Precision 6466 CEA 900HP Turbo!
Extreme PSI now offers a turbo to fill the gap between Precision's 62 and 67mm turbos! Introducing the NEW Precision 6466 CEA 900 HP Turbo! http://www.extremepsi.com/store/imag...GZjD610uGc.jpg Click Here to buy yours today! HP Rating: 900 One of our most highly-anticipated turbochargers, the 6466 is capable of producing unparalleled power in a relatively compact package. Combined with Precision's exclusive CEA compressor and CEA turbine wheel technology, the 6466 is one of the most potent turbochargers available. Ball Bearing Only PTE's PT6466 CEA Turbocharger features the following: • Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging • Higher efficiency and faster transient response for maximum power and performance • 64mm inducer compressor wheel • Compressor cover options: - "Ported S" compressor cover 4.0" inlet/2.5" outlet • Exclusive CEA (Competition Engineered Aerodynamics) 66mm, 76 trim turbine wheel • Turbine housing options: - T3 .63 or .82 A/R with 4 bolt (2.5") discharge - T3 .63 A/R with 5 bolt discharge (with or without wastegate hole) - T3 .63 or .82 A/R with 3" V-Band discharge - V-Band inlet .82 A/R with V-Band discharge - T4 .58, .68, .81 or .96 A/R with 3 5/8" V-Band discharge - T4 Divided .84, 1.0, 1.15 or 1.32 A/R with 3 5/8" V-Band discharge • Available with an air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) Thanks, Tony www.ExtremePSI.com 1-800-PSI-4502 215-244-4295 sales@extremepsi.com |
