Extreme PSI - SparkTech COP Systems!
Extreme PSI is proud to offer SparkTech ignition systems for your Evo! http://www.extremepsi.com/store/imag...covers_093.jpg http://www.extremepsi.com/store/imag...5Galo_PTLl.jpg http://www.extremepsi.com/store/imag...CU79du8r2j.jpg Whether you're on a stock turbo at 20 PSI or an 80mm turbo at 60 PSI, SparkTech has an ignition system for you. SparkTech takes the guess work out of the ignition by bringing complete systems with all new, high quality components. From connectors and wires to the coils and ignition boxes, it's all the best on the market. Not only will these ignition systems keep your plugs lit at high boost, they'll help smooth out idle, increase throttle response and even improved fuel economy thanks to the more complete burn. Click here to select the SparkTech system that is right for you! [/B] Thanks, Tony www.ExtremePSI.com 1-800-PSI-4502 215-244-4295 sales@extremepsi.com |
