StopTech & PF Rotors, Techna-Fit Brake Lines, Z-Pads, & More All On SPECIAL!
Guest
Posts: n/a
Street Package:
Stoptech high-performance replacement rotors are double disc ground to ensure parallelism. They are CNC machined and mill balanced to prevent vibrations. All rotors are e-coated to prevent corrosion and prolong durability. Stoptech’s high-quality and stringent quality control specifications assure that every component meets and exceeds worldwide ISO 9000 quality standards.
StopTech Slotted Front Pair - $202.30
StopTech Slotted Rear Pair - $168.30
All Techna-Fit stainless steel brake line assemblies are assembled in their facility to D.O.T. Certification.
The Evo 8 & IX brake line kits feature four lines with all the necessary fittings and brackets for a bolt-on installation
Brake Line Set (4) - $75.00
Project Mu B-Force Sports Pad is designed to improve overall braking performance of any street vehicle. The B-Force brake pad is developed for street and light track use where initial stopping power and resistance to fade is of prime importance. In addition to reducing brake dust and squeal, these long-lasting pads help keep rotor wear to minimum.
Project Mu B-Force Front Brake Pads - $99.00
Project Mu B-Force Rear Brake Pads - $95.00
-OR-
PF Brake Pads For Front - $114.75
PF Brake Pads For Rear - $108.00
Street/Light Track Package:
It's simple. You get the absolute best performance plus longer pad and rotor life.
Performance Friction's rotors are race proven in nearly every motorsports venue in the world.
For unparalleled performance and safety, upgrade to Performance Friction pads when installing your new PFC rotors.
PF Front Brake Rotors - $715.00
Z-Rated® pads are an extension of the Carbon Metallic® brand, specifically engineered for high-performance and/or severe-duty usage. Whether you drive a BMW, Corvette, Honda or Mustang, Z-Rated® is engineered to deliver safety and performance under even the most severe conditions.
All use our patented Ionic Fusion™ bonding technology, which offers the safest and strongest bond of the friction material to the backing plate
No rivets - You get greatly increased safety, performance and phenominal shear resistance.
Longer life - Our multi-layer bonded brakes pick up less road dirt, so you get longer pad and rotor life. This means you will spend more time on the road, and less time in the shop changing your brakes.
-OR-
If you have any questions please contact Greg or myself via PM or E-Mail at LC@GSCMotorsports.com
-OR-
-OR-
are those prices shipped? I need a quote to zip code 10567 for the stoptech rotors, brake lines, and project mu b force pads all 4 corners. THe lines come in different colors? Also do you sell brake fluid and if so what kinds and how much? Thanks in advance for your help and time.
