** Assaultech.com Suspension Sales - Tein Tanabe Stance KW KSport & More **
Coilovers
Buddy Club Coilovers - D1 Spec 03-06 Evo
Buddy Club Coilovers - Racing Spec 03-06 Evo
Cusco Coilovers - Zero-1 (Rubber Mount) 03-06 Evo
Cusco Coilovers - Zero-1 (Pillowball Mount) 03-06 Evo
Cusco Coilovers - Zero-2E (Rubber Mount) 03-06 Evo
Cusco Coilovers - Zero-2E (Pillowball Mount) 03-06 Evo
Cusco Coilovers - Zero-2R (Rubber Mount) 03-06 Evo
Cusco Coilovers - Zero-2R (Pillowball Mount) 03-06 Evo
D2 Coilovers - ProSpec Series 03-06 Evo
D2 Coilovers - Rally Series (Front Adj Aluminum Camber Plate, Rear Alum. Top Mount) 03-06 Evo
D2 Coilovers - RS Series 03-06 Evo (Front Adj Camber Plate/Rear Solid Aluminum Top Mount)
GReddy Type S Suspension 03-06 Evo (Adj PB 8kg/Rubber 6kg)
H&R Coilovers - Street Performance Coilovers 03-06 Evo
HKS Hipermax III 03-06 Evo (8kg/7kg)
HKS Hipermax III Sport 03-06 Evo (10kg/8kg)
Ksport Coilovers - Circuit Pro Damper System 03-06 Evo (PB/ATM)
Ksport Coilovers - GT Pro Damper System 03-06 Evo (7.5kg PB/7kg ATM)
Ksport Coilovers - Kontrol Pro Kit 03-06 Evo (7.5kg PB/7kg ATM)
Ksport Coilovers - Rally Spec AR Damper System 03-06 Evo (PB/ATM)
Ksport Coilovers - Version RR Damper System 03-06 Evo (PB/ATM)
KW ClubSport Coilovers 03-06 Evo
KW Variant 3 Coilovers 03-06 Evo (515/340)
Megan Racing Coilovers - Track Series 03-06 Evo (32 Way Adjustable)
Skunk2 Pro-Series Pro-C Full Coilovers 03-06 Evo
Stance Coilovers - AL+ Pro 03-06 Evo (9k/8k) (Front Camber Uppermount, Inverted Front Shock & Rear Helper Spring)
Stance Coilovers - GR+ 03-06 Evo (9k/8k) (Front Camber Uppermount & Inverted Front Shock)
Stance Coilovers - GR+ 3 Way 03-06 Evo (12k/14k)
Stance Coilovers - GR+ Pro 03-06 Evo (9k/8k) (Front Camber Uppermount, Inverted Front Shock & Rear Helper Spring)
Stance Coilovers - GR+ Pro SS-D 03-06 Evo (12k/14k) (Front Camber Uppermount, Inverted Front Shock & Rear Helper Spring)
TEIN Dampers - Mono Flex 03-06 Evo (14k/10k)
TEIN Dampers - Super Street 03-06 Evo (7k/6k)
TEIN Dampers - Type FLEX 03-06 Evo (12k/10k)
Tein EDFC Group: 12/14 Motors w/ Strut Kit - $395 w/ Coilovers
Tanabe Sustec Coilovers - Pro FIVE 03-06 Evo (8k/6k)
Tanabe Sustec Coilovers - Pro SEVEN 03-06 Evo (14k/12k)
Tanabe Sustec Coilovers - Pro SEVEN 03-06 Evo (12k/10k)
Tanabe Sustec Coilovers - S-0C 03-06 Evo (8k/6k)
Yonaka Coilovers - Spec II True Coilovers
