Affordable Brake Packages Available Now Exclusively Through MAPerformance.com
MAP Stage 1 Brake Package EVO VIII/IX
Package Includes
- Girodisc "Magic Pads" Front & Rear
- Techna-Fit Stainless Steel Brake Line Kit
- 1 liter of ATE Super Blue Brake Fluid
Girodisc "Magic Pads" are the solution to your squeeky, dusty, expensive factory pads. They have less dust than typical factory pads and much less than typical performance pads. Additionally, they have great initial bite, something most less expensive pads are lacking. But the real reason people like our pads so much is they are the "silver bullet" to brake noise problems. Magic pads are a semi-metallic composition that is easy on the rotors and the wallet. We recommend always replacing pads as a whole car set when switching compounds. Included is a set of our Pad Adapters (shims) for the full package.
All of Techna-Fit's assemblies are assembled in-house, to stock
or custom specifications, meeting D.O.T. Certification.
ATE Super Blue (DOT 4) has a dry boiling point of 536F and a wet
boiling point of 396F. ATE Super Blue is compatible and will mix with most DOT3,
DOT4, or DOT 5.1 Fluids. The overall high dry and wet boiling points make
this fluid an excellent choice for street driven vehicles where brake fluid is
flushed less frequently than in racing cars.
Available NOW for only $239.99 Shipped!
MAP Stage 2 Brake Package Mitsubishi Lancer EVO VIII/IX
MAP Stage 2 Brake Package EVO VIII/IX
Package Includes
RotorPros rotors offer maximum braking performance in applications with OEM rotor size and stock calipers. They are created from the highest quality (Centric) blanks to ensure the best heat dissipation and superior wet weather braking. The added air surface created by cross drilling, dimpling, and slotting will further increase the rotors ability to dissipate heat, cool your pads and discs, and protect against warping.
Available NOW starting as low as $479.99 Shipped
Package Includes
- RotorPros Performance Plus Brake Rotors
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE x 114|||||: Nate@MAPerformance.com
