Get Your DRAG Brake Needs at STM - This includes the all-new STM Rear Drag Kit!!!!
[/HTML]
No Matter What You're Looking For, STM Has the Parts You Need at The Best Prices!!!
STM Rear Evo 8/9 Drag Brake kits currently IN STOCK AND ON SALE !
http://www.streettunedmotorsports.co..._brake_kit.htm
Reduce Weight, Clean Up Your Engine Bay, Stop!
The STM OEM ABS Removal Kit
Get rid of that useless ABS System for your Drag Car or AutoX Car with 100% OEM parts and get the functionality you craved!
Compare that to the mess that comes stock!
The STM Staging Brake Kit
The STM Staging Brake / E-Brake Kit for Evo VIII-IX allows you to install a CNC staging brake, while utilizing your factory E-Brake handle.
All necessary hardware and high-quality stainless steel brake lines are included for install.
This kit only works on Evos without ABS and was designed with Drag racing in mind. We do not suggest road racing or anything like that with this kit. It will work fine for daily driving but it is intended for off road use only.
This is a detailed, technical Do-it-yourself install. If you are unsure of any components, do not attempt this on your own. Please have a highly reputable shop install this.
This kit WILL require some drilling, cutting and modification to your Evo!
STM FRONT Drag Brake Kit!
STM Front Drag Brake Kit for Evo VIII-IX allows you to ditch the weight of your big, heavy Brembos and rotors and clears room to run smaller wheels and slicks.
This brake set-up is specifically designed for Drag Racing.
This is not intended for constant, on/off braking as in road-racing or autocross.
The scalloped rotor is 2.7 pounds lighter than the standard rotor and is recommended for cars that see more miles on the drag strip than on the street. The scalloped rotor is not a street rotor.
These are available for pre-order. We have had huge interest in these.
We don't have any pictures yet, as we're still finalizing the final details. I can tell you they're going to save ABOUT 7lbs a side. Could be more, or less, but should be the absolute lightest option possible for your Evo.
They're on pre-order for $1000.
Justin at STM
Evo 'For Sale' Exterior Styling
64
Jul 19, 2021 08:38 PM
4g63girl
Aug 2, 2018 09:15 PM
STM Tuned
Jun 13, 2018 12:31 PM
