Stoptech Direct Replacment Rotors
Ok looking for a brake rotor upgrade or even a stock replacment that isn't $250 a rotor. check out stoptechs new direct replacment rotor line avalible in Drilled or slotted but not both. The centers are powder coated black so they wont rust and they are just as beafy as the stock brembos. The Slotted rotors will help with cleaning your break pads by removing gasses that build up under extream use. The Drilled, well they look cool and offer a little more cooling than stock but the performance gains are in the slotted.
http://www.gscmotorsports.com/images...cts/L_2885.jpg http://www.gscmotorsports.com/images...cts/L_2891.jpg Pricing for the front either Drilled or Slotted is $157 each or $314 for a pair. Pricing for the Rear either Drilled or Slotted is $135 each or $270 far a pair. A whole set all four corners of rotors either slotted or Drilled is $584. |
these are a great deal!
Are the drilled all the way thru or just dimpled cant tell in your pic. Also any warranty?
I have never had any of these type's of rotors can they be turned if needed in the future?
yes they can be turned and yes the holes go through the rotor.
looks like an excellent option for us, thanks {thumbup}
Do these rotors employ their special aerorotor design for superior cooling?
Steve |
im puting them on my xmas list
Do you have the weights of these rotors, front and rear?
wieght for the rotors i'll check on that one see if i can't get the shipping dude to put it on the scale by it self.
These do not employ the aero rotor design. now if there is some intrest I could get them to make a direct replacment 2 piece aero rotor for the evo. they have already done that for the 350Z/G35 with the Brembo so i know its possible. the cost is like $1000 and then $400 for replacments on the 350z so it would be about the same for the evo. As far as warrentty goes not really anything. If there is something wrong with the rotor they ussually wont leave stoptech they have the best quality control in the business. If there is a problem those guys are great about taking care of anything so a simple phone call to them and they will work it out. Greg |
Front 22 pounds per rotor
rear 15.5 pounds per rotor. These are very close to stock |
bttt
Greg I would be very interested in a two-piece aero rotor for the stock evo calipers. I have a friend that would be interested as well.
I think if you could price around 800-1000 there would be some good interest. Can we start a GP ? Steve |
Do you need to replace the brake pads if you use the slotted.
