Suspension Stages! Bilstein Struts + GTWorx Springs + Whiteline! Also KW Coilovers!
Introducing GTWorx Staged Suspension packages! The GTWorx Staged Suspension packages are designed as a complete system that comes together to provide a great handling/ride balance comparable to systems costing hundreds more. All this without the normal expense, maintenence, and hassle of setting up complicated coilover set-ups. Each stage works well on it's own, but leaves the option open to upgrade in the future. EVO MR drivers can stick with Stage 2 and retain the fantastic ride quality of their OEM Bilsteins. Other EVO drivers can go all the way to Stage 3 to Bilstein HD dampers and appreciate a huge improvement in ride quality, while transforming their car's handling characteristics with the proven GTWorx springs and Whiteline rear swaybar. These are a great alternative to the common cheap Chinese coilovers that most people just don't need. ------------------------------------------------------------------------------------------ Stage 1 - $275 shipped -GTWorx Springs Stage 2 - $439 shipped -GTWorx Springs -Whiteline 24mm rear swaybar Stage 3 - $1125 shipped -GTWorx Springs -Whiteline 24mm rear swaybar -Bilstein HD dampers http://www.rcephotos.com/photos/albu...1443_sized.jpg http://gtworx.com/catalog/images/Whi...%20Swaybar.jpg http://www.innerauto.com/images/bran.../bilstein2.jpg ------------------------------------------------------------------------------------------ Whiteline Geometry and Bushing Package - $399 shipped Whiteline Roll Center Kit Whiteline Bumpsteer Correction Kit Whiteline Rear Trailing Arm Bushings Whiteline Front Control Arm Bushings These Whiteline Geometry and Bushing parts correct the adverse effects of lowering an EVO while removing a lot of the "slop" from the stock bushings. Firmer bushings prevent dynamic changes in camber, caster, and toe, while the Roll Center Kit relocates the roll center of the car, correcting a side effect of lowering an EVO. These parts make a great addition to GTWorx Suspension Stages or any coilover system. http://www.rcephotos.com/photos/albu...ne_ca395_1.jpg ------------------------------------------------------------------------------------------ Please PM or call if you have any questions about which GTWorx package is right for you! - Andrew |
Dave Mac KW Variant 3 Coilovers With Whiteline Camber/Caster Plates Wanna win your next autocross or time attack? These will help. http://www.globalperformanceparts.co...es/KCA252M.jpg $2549 for custom rate and tuned coilovers with Whiteline Camber Plates!!! $2249 shipped without plates!!! We worked extensively with Dave Mac this season to develop these custom KW Variant 3 coilovers. A variety of ride heights, alignment settings, and damper settings were tested throughout the year until we found the ultimate STU autocross set-up. Countless autocross wins and podiums later, we can now offer the Dave Mac KW Autocross Special!!! Whiteline camber plates use the biggest spherical bearing we've ever seen for EVO, meaning these will be silent and last a long time. One of the few plates that also adjusts caster too! • Independently adjustable rebound and compression damping • inox-line stainless steel technology, rust PROOF. • Individual height adjustment • German TUEV-tested adjustment parameters • High-quality components for long life • Comprehensive documentation for ease of use • Infinitely adjustable rebound damping • 14- level adjustable compression damping ALL Set-up instructions included. Ride height, bump and rebound settings, alignment settings, everything you need to put on and win! Please call if you have any questions or would like to order! CALL 410-579-1501 |
GTWorx EVO Springs The long awaited "mild drop" high performance spring for your Mitsubishi Evolution. Having a much more subtle/mild drop in comparison to most aftermarket springs, these are perfect for EVO owners not looking for a ride height much lower then stock, and yet are still looking for spring rates that are tailored to the track and auto-x course. These maintain great ride quality while delivering performance on par with many coilover systems! Spring rates: 10% stiffer then Swift Springs Drop: 20mm front 15mm rear GTWorx/Racecomp Engineering Street/Track Springs - $275 shipped!!! IN STOCK Please call 410-579-1501 to order! |
Ohlins DFV Sportline Coilovers Just Released!!! http://www.rcephotos.com/photos/albu...ohlinsdfv9.jpg 450lb/in Front, 560lb/in Rear main springs 25 clicks of rebound adjustment Adjustable front camber plates Pillowball rear mounts Inverted front strut design Includes Eibach main springs Ride Height adjustment seperate from preload $3150 Shipped!!! Custom Rates Available!!! Ohlins Fixed-Perch Struts http://www.rcephotos.com/photos/albu...ixed_perch.jpg 25 clicks of rebound adjustment Uses OEM style springs Ultimate Ride Quality $1699 Shipped!!! $1849 Shipped with GTWorx or Swift Springs!!! |
We will match (almost) all Whiteline and Swift prices!!! Swift Springs -- $276.75 shipped http://gtworx.com/catalog/images/Swift%20EVO8.gif ------------------------------------------------------------------------ Whiteline Roll Center Correction Kit/Ball Joint Extenders - $179 shipped http://www.rcephotos.com/photos/albu...ne_ca395_1.jpg ------------------------------------------------------------------------ Whiteline Bumpsteer Correction Kit - $59 shipped http://filebox.vt.edu/users/sekellic...evobumpkit.bmp ------------------------------------------------------------------------- Whiteline Trailing Arm Bushings - $89 shipped http://filebox.vt.edu/users/sekellic/pictures/W0594.jpg Please CALL 410-579-1501 to order!!! |
Do you have the Bilstein HDs in stock? Please pm me to let me know if you do and how much they are.
pm sent
bump!
Bilsteins IN STOCK! Call now!
bump for great service and awesome products from GTworx!
Originally Posted by vroomevo
(Post 5244889)
http://www.chicagoceg.com/gallery/al...rpics/pic1.jpg http://www.chicagoceg.com/gallery/al...s/rear%7E0.jpg |
How much for Bilstien and Swift combo?
^ It would add an extra 20 bucks.
- Andrew |
(Post 5244889)
Originally Posted by I-Dom-In-8
(Post 5246797)
Ditto..i couldnt be happier with my GTworks spings..
http://www.chicagoceg.com/gallery/al...s/rear%7E0.jpg - drew |
bump! bilstein HD's in stock!
