Need help fitting those new wheels? Get some extended studs or spacers...right here!
http://www.maperformance.com/img/forums/evom-header.jpg http://www.maperformance.com/img/forums/sep.png http://www.maperformance.com/marketi...wheelstuds.jpg ARP Extended Wheel Studs These extra-long ARP wheel studs are designed for today's thick-centered, high-performance and racing wheels. These chromoly steel studs are heat-treated and have a 190,000 psi tensile strength rating. http://www.maperformance.com/marketi...udsspacers.jpg Ichiba Exended Wheel Studs and Spacers ICHIBA extended wheel studs / bolts were designed to meet our wheel spacers' safety requirements. All wheel studs/bolts may be used as replacement parts or with ICHIBA spacers. ICHIBA wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacer is a two piece design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety. http://www.maperformance.com/marketi...ICSspacers.jpg Project KICS Wide Thread Wheel Spacers Direct from Japan, the KICS wide thread spacers are used to bring out the wheels of your car outer to give aggressive look and close the space gap. The KICS wide thread spacers are also used to clear spacing between your big brake kit from the wheels. These spacers come with new studs already installed with all necessary hardware. Available in 15mm, 20mm, 25mm, and 30mm for most popular Japanese vehicle applications (1.5mm / 1.25mm). http://www.maperformance.com/marketi...FABspacers.jpg JM Fab Wheel Spacers EVO/DSM hubcentric wheel spacer, CNC machined from 6061 aluminum. Designed for use with aftermarket wheels, will NOT work with OEM wheels. May require longer wheels studs. Sold as a pair. Keep in mind that this is only a small sampling of what we have available. Don't hesitate to contact us to get what you're looking for. http://www.maperformance.com/img/forums/sep2.png Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"! http://www.maperformance.com/img/forums/pm.png: Send us a PM|||||http://www.maperformance.com/img/forums/aim.png: AdamAtMAP|||||http://www.maperformance.com/img/forums/phone.png: 1-888-MAPERFORMANCE|||||http://www.maperformance.com/img/forums/email.png: Adam@MAPerformance.com http://www.maperformance.com/img/forums/social-bl.png|||||http://www.maperformance.com/img/forums/social-fb.png|||||http://www.maperformance.com/img/forums/social-tw.png|||||http://www.maperformance.com/img/forums/social-yt.png http://www.maperformance.com/img/forums/footer.png |
Have a great weekend!
i need some ichiba v2 20mm spacers w/ built in studs!
do you have them in stock or drop ship because i hear they are on b/o from the manufacture |
That is correct, the 20mm versions are on backorder right now. They don't have an ETA listed currently.
Originally Posted by maperformance
(Post 9549708)
I don't have any in stock because they have been on backorder for a little while now.
Post on our facebook page letting us know how your weekend went at the Buschur Shootout!
www.facebook.com/modernautomotiveperformance |
bump!
HaHa, Thanks!
Listening to Slipknot bump!
bump!
Sunday bump, woot woot!
pm me price on two 25mm kics spacers shipped to 91306 please... thanks
You got it!
Late night bump, shoot me a pm if you need anything!
